Support DIY and Instructables : Become a Pro Member Today!
Run Homebrew on any Wii
This instructable has been removed by the author.
83 comments
1-50 of 83
May 20, 2009. 5:52 PMtraidam says:
Can we use SDHC(Secure Digital High Capacity) card or have to be SD(Secure Digital) card????
May 18, 2009. 1:33 PMtraidam says:
let me get it straight. all i have to do is install cIOS36 Rev 7, Install DVDx, and Install backup Loader 0.3 and i'm ready to burn any wii games and play.. Am i right? SD card have to stay inside Wii system, right?
Dec 21, 2008. 2:07 PMbuckno1 says:
Could someone please help me when I am trying to install Homebrew I get to the screen which says the following: -
Loading installation data
Checking system.......
I'm running under IOS21 2.2
Error checking the System Menu version!
And then it just goes to the WII menu again, any advice would be much apprecited.
Apr 29, 2009. 9:19 PMmrcorenthos says:
hi there,
i was wondering if you had any success figuring out this issue.
I have run into the same issue while trying to do the softmod today.
any help would be much appreciated
thank you
Feb 25, 2009. 2:18 AMaznnotorious says:
DO I NEED TO HAS zelda GAME TO INSTALL THIS SOFTWARE. CUZ WHEN I GO TO MY SD CARD ALL I SEE IS Twilight hack FOR (USA, EUR, JPN). WHEN I Go to the SD Card Tab and copy ON TWILIGHT USA TO THE HD IS SAY " YOU HAS TO PLAY THE GAME BEFORE YOU SAVE." PLEASE HELP ME OUT.. THANKS..
Apr 29, 2009. 3:33 AMnightninja87 says:
u do need the twilight zelda wii version of the game to do this
Feb 25, 2009. 9:33 AMronunderdog says:
insert the zelda
create a save file
go to the wii memory
delete the zelda save file
go to the sd card and copy the twilight hack to the wii
Apr 22, 2009. 5:28 PMf86sabre says:
what about version 4.0?
Apr 14, 2009. 5:50 PMsteed1172 says:
is there anything i can do for a "bricked" wii?????
Apr 14, 2009. 5:51 PMsteed1172 says:
oh and... can i do this with gamecube zelda version?
Mar 21, 2009. 12:55 PMwatchurmouthyoungman says:
could you get banned from playing online?
and can you go online in homebrew?
Mar 21, 2009. 11:41 AMstomp_442 says:
first thing you need to do is format you SD card (2 GIG or smaller non SDHC), then put the version of the hack that matches your firmware, then put the homebrew channel stuff on your SD card. Also take note of the number that is stamped around the center hole of the disc (U.S.A. only), does it end with a 0 or a 2? remember the last number. there are very detailed instructions that come with the twilight hack. make sure you have the Zelda game. yes, you have to play the game and make a save game. this save game goes onto the internal memory of the wii. then restart your wii with the memory card installed, but not the game. delete the save game from the internal memory, then copy over the hack from your SD card. exit back to wii menu and start zelda game. load your save game and there will be a choice for the U.S. version on which save game to load 0 or 2, the number that's on the disc. I had a disc with a 0 on it and i loaded the top save game. once the game starts talk to the man or walk backward and homebrew channel will install. after that you may uninstall the twilight hack from SD card, it's no longer needed. the rest of the stuff must stay on the SD card for homebrew channel to work. Before you start the Twilight Hack, make sure your SD card is setup right. when you have it in your computer, open up the card and you should see a folder that says private (thats the twilight hack), another folder that says apps (homebrew channel), and a file that says boot.dol
Mar 14, 2009. 4:25 PMN1CK4ND0 says:
Wii is teh uber.
Feb 24, 2009. 9:07 AMfattymcbutterpants says:
I have version 3.3u can it be installed onto my wii? i read somewhere that ver. 3.3 blocked homebrew...
Feb 22, 2009. 5:27 PMbobbo1420 says:
i have Ver. 3.4u is there a way to still install homebrew?
Feb 16, 2009. 3:43 PMcheckered flag says:
i have followed your directions and several others directions and i can't get passed " exception 0300 occurred what am i doing wrong i think it has something with the way i am doing the files please help beforwe i pull my hair out it is driving me nuts thanks
Jan 22, 2009. 4:34 PMinstructablesmeg says:
Had a problem where my 3.2u Wii was not seeing the twilight hack save had to do the following for it to see the file. happy homebrewing all.
http://wiibrew.org/wiki/Twilight_Hack
Note: Some people are having problems with the Wii not "seeing" the save file on the SD card. If you are experiencing this, try setting the archive bit for the data.bin file - in Windows this can be either be done from the file's properties dialog (right click on it in Windows Explorer and check the box) or from the command line using "attrib +a <path to data.bin>".
Jan 12, 2009. 8:21 PMjustin22345 says:
no its a sd card not sdhc.. and I renamed the apps to boot.elf... its just says when I format the sd flash erase has been canceled because this device doesnt support it. were using a scandisk 2gb like below poster any help?
Jan 10, 2009. 9:10 PMjustin22345 says:
my wii says failed to read boot.elf
so I formatted the sd the way they told us in trouble shooting but whenever it finishes it says flash erase drive has been canceled because this device doesnt support it. Any help?
Jan 11, 2009. 11:18 PMSolderguy says:
It is a sdhc card or a sd card? SDHC cards don't work with the wii. Also, use your computer to format your sd card,but be warned, formatting your sd card will permanently erase all data on it. Try renaming boot.elf to boot.dol.
Jan 11, 2009. 12:52 PMjustin22345 says:
thundaboy1047 need your help...read my first posting....thanks in advance
Nov 18, 2008. 2:28 PMquazimoto says:
does it matter if its the gamecube twilight princess?
Jan 10, 2009. 9:51 AMDYLEGO says:
go rent the game
Jan 6, 2009. 5:38 PMDYLEGO says:
it has to be the wii one
Dec 13, 2008. 4:12 AMarienh4 says:
Of course it does. Entirely different game.
Dec 21, 2008. 7:41 AMkyogre says:
hey....i am a noob here...
so pls help me?
if the game zelda is a US game...how will it work on a PAL wii without modchip to install the homebrew channel?
Pls be kind to help me...
Jan 6, 2009. 5:37 PMDYLEGO says:
all you need to know is... it works without a modchip. millions of twilite hack users can vouch for that.
Jan 9, 2009. 11:45 PMSolderguy says:
I doubt that, or Nintendo will freak out. I for one, vouch on that it works on my wii.
I wouldn't doubt it. There are more than 6 billion people in the world, and a few million people using the Homebrew Channel wouldn't freak anybody out. With some people, the way it works is that if you get a conxole, you just have to hack it.
Aug 24, 2008. 6:37 AMzach12 says:
is there any possible way i can get homebrew without the game zelda
Jan 5, 2009. 4:33 PMCapt. Fat says:
Hey Twilight Princess is awesome!!!! You leave Zelda out of this!!!!!!!!!!!
(Joke)
Aug 24, 2008. 4:43 PMzach12 says:
i only need the game once?
Jan 10, 2009. 1:32 PMSolderguy says:
If you liked the game you could just copy it and return the original.
Jan 6, 2009. 5:36 PMDYLEGO says:
the game is only used as an installer for the hack, basically yeah, only once. then you can return it, but the channel will be on your wii, so its ok.
Dec 21, 2008. 2:40 AMSerry says:
I have version 3.2 will it work with that? or is my system to old??
Dec 10, 2008. 8:17 AMcpjolicoeur says:
The download file for the SD card files does not contain DVDx. The DVDx folder is there in the Apps directory but there is no content inside.
Dec 19, 2008. 2:48 PMwinkep58 says:
did you ever get an answer to your question...I have the same problem...no file in the folder. Thanks.
Dec 19, 2008. 3:07 PMcpjolicoeur says:
I ended up using another much easier method that doesnt even need DVDx.
Check out this tutorial, it worked perfectly for me and now I can play burned games no problem:
http://www.wiihacks.com/faq-guides-tutorials/7199-3-1-3-4-twilight-downgrade-starfall-gammatutorial.html
Dec 19, 2008. 5:48 PMwinkep58 says:
Thank you so much...this worked perfectly!
Dec 16, 2008. 9:03 PMfxnoob says:
Hi Thundaboy.
Thanks for your guide. Sorry if this sounds stupid. After i have installed this homebrew program, can i revert it / uninstall it from my Wii again? Would it cause any issue if i am going to play originals Wii CD on my wii system? Thx.
Dec 13, 2008. 1:48 AMdigitalriceriot says:
i just updated my wii on dec15... its this hack still gonna work for me?.>
Dec 13, 2008. 4:11 AMarienh4 says:
I don't think so. By the way, how can you have updated on dec 15 if it's dec 13?
Dec 14, 2008. 10:55 AMarienh4 says:
There was one in November.
Dec 6, 2008. 1:20 PMfuadhossain says:
is there a way to run homebrew channel without buying zelda twilight princess
Nov 21, 2008. 5:19 PMsoccerskyman says:
Crap! I JUST updated my wii!
1-50 of 83
Related
