Hacker / Nerd Needle and Thread
1,054
Published
Introduction: Hacker / Nerd Needle and Thread
You are a nerd and hardware hacker and do not shy away from a challenge. Collecting skills is your thing. But then you encounter a project so daunting. Your shirt losses a button and you need to use needle and thread. If this describes your attitude towards needle and thread. This is your instruction guide.
Step 1: Sorting and Picking the Needles With a Breadbord
The person who invented the cheap sowing kit has never considered that Nerds exist. If you buy a set it comes with several kinds of needles but what is the difference? Use your breadboard as a guide. If you put a needle in you can immediately see the difference between different and compare needles. Some are longer some have bigger hole to put the thread through etc. Pick the one you think fits your project best.
Step 2: Threading a Needle
You can use your breadboard again in this step. Take the needle you like to thread out of the line-up. Cut off a piece of thread. Make the end wet to straighten it. Push the tread through the hole. You can use normal people instruction from here on http://www.wikihow.com/Sew-a-Button
Step 3: Sugru
Well this last step is not really necessary but still a fun hack. You can use a needle and thread to stitch ripped Sugru together. But be careful the cheap needles might break so use pliers to get the broken needle out.
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    3 Discussions
    I appreciate your problem-solving approach to problem-solving. Isn't sewing a button on a shirt one of the things on Heinlein's list of 20 Skills Every Human Should Have?
    I don't know what I do know is that sewing has not had any innovation in the last years and I see a lot of potential for hackers. Fishing wire and sewing is one. More instructables on this topic are on the way.
    You comment motivated me to finish an instructable I had as an draft
    https://www.instructables.com/id/Nerd-Hacker-needle-thread-and-needle-threader/
