Introduction: Hacking DVD/Videogame Physical Security
*WARNING*
I warn against the use of this instructable for illegal activity. I have provided this information for learning and entertainment use only. I take no legal or moral responsibilty for your actions.
Now that that is out of the way, some backstory. I started this project when my Dad bought dvd's from a Hollywood Video that was about an hour away, brought them home, and found that the cashier had left in the security bar that keeps you from opening the box. After tearing apart one box, utterly destroying it, i figured out a better way.
This is my first instructable. I will be trying to improve my skills as i continue to produce further articles.
Step 1: Gather Your Materials
First off, gather your materials. They are:
A movie with the red thing inside it (image two)
An incredibly strong magnet
A smaller but still strong magnet
The incredibly strong magnet was hard to come by for me. I tried making an electromagnet, but i couldn't get it strong enough. I don't have the money to go out or order from one of those retailers, so i spent two afternoons drilling through an old 3 gig hard drive (i told you it was old). The magnets inside harddrives are amazingly strong, so strong they can chip and break if you let them snap together, so be careful. The smaller magnets i bought at a Storables. Just look for any office supply store and look around the whiteboards.
Step 2: Lets Take a Lookie at That Red Thing
Though very simple in mechanics, the little red thing (from now on refered to as the lock) is made up of two parts. The first part is a small metal block that is wedged into the end of the lock, which i couldn't get a picture of that wasn't in shadow.
The second part, which is shown, is a thin piece of metal which protrudes away from the bar. This is the actual locking mechanism. It catches on a lip of the case, thereby making it difficult to remove.
Step 3: Let's Crack This Baby Open
When you place the smaller magnets on the lock, the piece of metal is pulled back so it is flat with the lock, allowing you to slide it out. Therefore, placing the magnet is on the side of the box is our first step.
The second step is to push down on the actual lock. I do this because some times the small piece of metal gets lodged in the case from previous people trying to pull the lock out. Pushing it back into the case allows the magnet to pull the metal bar flush with the lock.
The third step is to place the strong magnet onto the lock, covering it from view. Try to slide the strong magnet onto the lockface, as pulling on the lock before the stronger magnet has its full grip can conteract step two. This part can be tricky, depending on how powerful the magnet is, as the smaller magnet is attracted to the larger magnet and often becomes unattached from the case. Use both hands during this process.
Pull on the strong magnet, thus removing the lock. Be careful as the smaller magnets will fall off, and i assume you either dont want to spend more money or search around for it. Make sure you can catch it.
Step 4: Ending Notes
So there you have it folks. Simple. Easy. My next project is hopefully going to be a little more complicated: getting into those full-covering anti-theft cases.
One note before you try this. Using the magnet can cause some slight stretching of the plastic cover on the dvds. This damage is minimal, so i would still recomend this method, but if you have a problem with imperfections, be warned.
I again warn against the use of this instructable for illegal activity. I have provided this information for learning and entertainment use only. I take no legal or moral responsibilty for your actions.
