Step 3Let's Crack This Baby Open
The second step is to push down on the actual lock. I do this because some times the small piece of metal gets lodged in the case from previous people trying to pull the lock out. Pushing it back into the case allows the magnet to pull the metal bar flush with the lock.
The third step is to place the strong magnet onto the lock, covering it from view. Try to slide the strong magnet onto the lockface, as pulling on the lock before the stronger magnet has its full grip can conteract step two. This part can be tricky, depending on how powerful the magnet is, as the smaller magnet is attracted to the larger magnet and often becomes unattached from the case. Use both hands during this process.
Pull on the strong magnet, thus removing the lock. Be careful as the smaller magnets will fall off, and i assume you either dont want to spend more money or search around for it. Make sure you can catch it.
comments
Add Comment
Add Comment
