Update May 2012-
I would have a bootable USB stick and run a pocket LINUX version today. Or if USB Boot is disabled in the BIOS then the Phone tether method also works with USB or wirelessly. Then you have no filters, blocks or issues. You can install anything and run it to access the network.
Now that everyone has phones with internet service is no big deal to get to your mail and webpage anymore.
It is cheaper to use WiFi calling or surfing than 3G or 4G services, so look for open or public WiFi and use your phone connected and preferenced to WiFi at home, work or mall etc.
Stuck at school? Setup your phone to VNC or RDC "remote" into your computer at home. Then just control from anywhere.
Grounded, cut off....awwww. Even game consoles can run LINUX. If you have anything with a CPU someone has unlocked it.
Description:
At school, in a library or mall and have access to a PC but cannot "surf" to any thing but their one site or a "filtered" subset of the internet?
Is Youtube blocked?
Is iTunes, Bittorrents or other sites blocked?
Can you not download or installed software?
Ok...we'll try to help you dorks out.
ERCK
Remove these ads by
Signing UpStep 1: Overview
They have to block ALL exploits and all access to command line, process startup/control and downloads...plus keyboards, admin roles, powerusers or even USB ports and BIOS firmware!
if ANY of these are exploitable then we have means to attempt to access any system's internet access....or a cooler idea is to enable a PC's "ICS" Internet Connection Sharing, or peer-to-peer wireless 802.3 even Bluetooth and use your Bluetooth or WiFi phone, pda or itouch to then surf 'unobstructed' ! hehe
I'll provide follow-up steps for EACH below as time permits.
1) Simple browser filter or cheap software like netnanny etc.
We exploit this with a proxy or web redirector and kill -f process name or id
2) Advanced Network filter and site blocking
Many proxy or redirector will bypass these as well, where they do not we also use advanced proxy services like the Vidalia bundle , TOR, Prioxy & Vidalia
3) Keyboard disabled or missing
OH soooooo easy, Microsoft allows for "disabled" users with an on-screen keyboard! duh
4) Kiosk Mode IE
OMG even easier! ALT+f4 logs off IE and then start whatever you want as above or see below....
5) Starting and stopping processes, killing or modifying msconfig etc
helpful for custom downloads or setup of exploits above
6) Basket / Corner cases
tough nut? Post your isseus
You need to research the environment, use human engineering develop specific exploits and then go get 'em...
Visit Our Store »
Go Pro Today »
You only see what is front of you! Not the possibilities! Open your mind. Feel the power of the farce!
Ok enough Yoda channeling. Guys you must adapt, improvise and overcome. So you have a Mac or PC or proxies, firewalls and DMZ etc. Please ever heard of hacking?
Two ways -
1. Social engineering. My fave, get a keylogger (usb or software) install it then break or lock your machine. Admin comes to fix, captures ID and password. And then do as you wish.
2. Reboot any Mac (They have Intel chips... you can even dual boot Windows!) or PC to a Linux build from your USB. Try the new Unbuntu it has all the drivers,USB loader and all!
Then add your new OS any proxy, IP redirect or use Admin to open ports or proxy. Heck run your own proxy on a VM and give the address to anyone to bypass defaults, plug a portable hotspot or thethered 4G phone into network and access from anywhere to allow unlimited Net access over wifi or LAN via your new VM proxy on Linux!
Go padwan and explore...
Master ERCK
The Internet is FULL of easy to follow well documented process and programs to find anything. Now most of us have 4G phones with tethering so you can use any computer to make or access your own network, Wi-Fi or high speed wireless.
It is a waste of money to filter, block and try to process ALL the network traffic sent thru even a medium sized school or businesses Internet traffic. They do this to protect themselves not to prevent you from access.
As always use this as a learning experience and be kind...
ERCK
Anyway proxies are alright but not very consistent plus they would usually get blocked by pro-active eventually.
Iuse highspeedVPN I'm usually on the move for work and I find that it works perfectly when I'm abroad. Check it out http://www.highspeedvpn.com/
My school gives away macs to students in year 9+ and specialist programs. We use the same internet as the rest of the school. My friend and I discovered this while playing around with proxies. Just go to your wifi settings/ network preferences. For mac, click on WiFi, advanced, then proxies.Then, for HTTP and HTTPS set the server to 10.1.81.11 and the port to 8080. For iOS software, go to WiFi, then click the blue/white arrow next to the connection name. Scroll down (I think) till you see proxies. Tap on manual. Put the same server name and port in.
I don't know if the server and port will be the same for every school, but for your sake I hope so. If anyone can get this working for anything that's not apple, please tell me so I can get it working on my phone.
P.S. It removes school blockades, but not government blocks, which means no Newgrounds.
Use the Linux or a VM for a browser and a public redirector for bypassing blocked keyword content...
What did you try? You typed it in, it didn't work and so you gave up?
Can you install and download software on the machine? If so you can do anything. If you lack Windows Admin or OS X root then you must use url redirectors or proxy servers.
The eaiest these days is a cell phone in teather mode. You can teather your 4G wireless to the PC via USB, Bluetooth or WiFi. Just setup phone teathering or download a App for your Mobile OS and then connect via USB or WiFi. Surf away.
If these are blocked then read steps above and find the opening. What CAN you do on that machine. I had a library PC that had no keyboard, browser was locked in Kiosk mode. No problem... there is a onscreen keyboard, I just killed the process and started IE.
ping *DOMAIN*
