3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacking The Spy Video Trakr With Frickin' Laser Beams...And Missiles!
Hacking The Spy Video Trakr With Frickin\
Courtesy of CPT Hans.
I bought a USB-powered foam missile launcher, which has pan & tilt, and even a targeting laser! I'm powering it from the Trakr's internal USB port, and controlling it with the GPIO lines.
Step 1
The original control board was quite sophisticated
It has an IC that receives USB commands from the windows application and outputs control voltages on several different pins to control the motors, etc.
I'm going to use an H-bridge IC and a few transistors to accomplish the same task. It will certainly be much simpler than the 15 transistors, 20 resistors, and 9 capacitors that the original circuit contains!
I have all the wiring figured out, and have tested the control circuits...I'm just waiting on the H-bridge chips.
I wish the remote had more buttons. As it is now, you have to move into firing position, then stop and run the launcher app. The two joysticks on the remote control pan and tilt, button A toggles the laser on and off, and each press of button B fires a missile.
Since it's a stop-and-shoot situation rather than shoot-on-the-move, it's more like artillery than tank vs tank combat.
3 comments
Apr 15, 2012. 11:35 AMDouglasG1 says:
Did you build the program in C# ?
Dec 18, 2011. 12:26 PMAddi.Zo says:
Very nice instructable! This must have taken a long time. Did you purchase the missile launcher from Thinkgeek?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:KRA5H(Fun With Snap Circuits)
IT professional.
