3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacking With Notepad
  • last photo ←
Here is how you do a cool little hack with notepad. What it does is pops up a command prompts and overloads the computer and the computer CRASHES!!!
FOR EDUCATIONAL PURPOSES ONLY!!!!!!!
Step 1NotePad
First you need to open Notepad.
You can go to the start menu and Click "All Programs", Then find the Folder "Accessories"
and "Notepad" should be in that folder.
Or you can open the start menu and type "Notepad" and click enter and Notepad will open.
Go To Next Step---------------------------------------->>>>>
61 comments
1-40 of 61next »
Apr 24, 2012. 11:14 AMhacker3456 says:
Try This:
@echo off
title proxy
cls
nslookup
save as web bat..... Its like a proxy use it to get past blocks.... depending on your schools security it should get past most...
Have fun
Jan 6, 2012. 4:12 PMShowdownVD says:
Thank you. I can provide a matrix code hack if you guys want. If you leav it running long enough, it will fry the cpu, causing severe damage. It makes it run at full capacity as long as it is open. It's cool to see, but it's intended as a pic file, or a means of revenge. It's bad to accidentally use it on yourself...
Nov 1, 2011. 2:38 PMbtheodorsson says:
does it work to just reboot the computer????
Jul 17, 2011. 4:37 AMjlim8 says:
@ECHO off
:Begin
msg * Hai
msg * How are you dear….
msg * I am fine ya!
msg * Lets have fun together!
msg * Because you have been o-w-n-e-d
GOTO BEGIN
YOU CAN STOP IT TYPE IT IN NOTE PAD SAVE IT S .bat THEN TO STOP THIS THING PRESS CTRL ALT DELETE END THE TASK
(THE REAL REAL REAL REAL REAL REAL REAL WAY)
Jun 8, 2011. 11:48 AMFoxx4050 says:
Seriously?!?! Looks like you can't hack your way out of a paper bag...
Oct 28, 2008. 12:58 PMMavc0rz says:
Wow! Nice man, but is it just to reboot the computer and everything is back to normal? Greetings, Mavc0rz
Dec 20, 2008. 10:12 PMPR1V4T3H4CK3R says:
i know how to make the real deal..the TROJAN VIRUS...it deletes your hardrive and pretty much destroys your computer..
Feb 4, 2009. 12:55 AMZelka says:
Trojan Virus...really. Here i was thinking something about horses...
Mar 9, 2009. 10:44 AMMavromatis says:
Yeah, tiny horses.
Jun 8, 2011. 11:45 AMFoxx4050 says:
Tiny wooden horses...?
Sep 28, 2010. 10:43 PMblacklistspy says:
its a type of batchfile..................its cool
Nov 28, 2008. 8:13 PMalex_jines says:
try this... open notepad and paste this, and save it to VIRUS.BAT file. OFCOURSE YOU CAN EDIT IT!
@echo off
title axle_66 virus
color 04
echo YOU HAVE BEEN INFECTED BY AXLE_66 VIRUS!
pause
echo TERMINATING PROCESSORS.....
pause
echo DESTROYING INTERNAL DATA....
pause
echo ACCESSING HARDISK CRACHER.EXE
pause
echo DELETING STORED DATA
pause
echo ACCESS GRANTED
pause
echo KILLING COMPUTER
pause
echo INFESTING PARAMETERS
pause
echo AXLE VIRUS ACTIVATED!!!
pause
:1
dir/s
goto 1
Jun 18, 2010. 7:28 AMcazador001 says:
nice man that one will really make people flip. lol
Feb 21, 2010. 6:50 PMonlylooklikepackrat says:
I would like help with a "hack" to enable magicJack VOIP use at school. The program on the device comes up but it can't get through the firewall to use the appropriate UDP ports. Any thoughts on this?
Nov 5, 2009. 6:02 PMshoyru_master_11 says:
This could be a real hack???
May 16, 2009. 5:22 AMdarkferret0 says:
not much use.
Oct 17, 2009. 6:43 AMColonel88 says:
no, but you can do some pretty wonderful things with .bat files.
type in: "start intercpl.cpl". It opens up the internet options if you can't  or if it is blocked and then you can switch it around and install a proxy on a blocked PC and unblock sites!
Mar 7, 2009. 4:48 PMnimann says:
wtf not hacking, called SCREWING AROUND!!! theres no permanent damage.
Aug 30, 2009. 2:21 PMnitendo9 says:
... you want to be mean and kill peoples computers??? besides, that was not screwing!
Jul 2, 2009. 11:13 AMeyereric says:
A much more powerful command would be: "@echo off x: Start FILENAME.bat Start FILENAME.bat Start FILENAME.bat Start FILENAME.bat Start FILENAME.bat echo Z0MG, I H4X3D U!!! @echo off goto :x" Of course replace "FILENAME" with your... well, your file name. This also would have to include your location such as "C:\H4X\batches\FILENAME.bat" Plus you'd probably want to have at least 20 of the "Start" command, I'm just lazy.
Aug 21, 2009. 10:35 PMoctavian234 says:
oh nice that is like a fork bomb
Aug 4, 2009. 2:23 PMwizerd 745 says:
This is not a hack, only a simple fork bomb. Virus is a more ,but still a stretched, name for it.
Jun 24, 2009. 12:19 AMcasper slok says:
Well I think its a nice one, not a hack but anyway, going to screw some people:P, does it works the same if I call it, Word,documents or anything else ?
Feb 5, 2009. 12:10 PMhq says:
Man how for erm... noobs and beginners
On my site we are working on hacking in to windows at the moment and making something like yours but a bit better in c which is a better language.
You can take the code from my site so you can make a newer and better tut on this site:
http://www.crackthissite.piczo.com
Jun 10, 2009. 12:37 PMdla888 says:
You do realize that batch files ca only do so much. They are a series of commands NOT a programming language.
May 16, 2009. 12:26 PMKing doom64 says:
Doing this with the notepad is a glitch.
Apr 20, 2009. 8:57 AMneo121 says:
its not a hack!!
Apr 9, 2009. 11:20 AMTheFoerignMan says:
you say you cant stop it... well you can: just Ctrl+C... thats it. it'll say "do you wish to abort? (Y/N)", you type "Y", and it's stopped. Also, this isnt a hack, but a prank. a good one though!
Mar 21, 2009. 8:58 AMlokendra26 says:
a good trick
Feb 1, 2009. 12:17 PMfrankfarms says:
i>wonder>what>would>happen>...>i>wonder>what>would>happen>...>i>wonder>what>would>happen>...>i>wonder>what>would>happen>...>i>wonder>what>would>happen>...>i>wonder>what>would>happen>...>
Jan 22, 2009. 8:09 PMbleachworthy says:
fail... like; hella fail.
Jan 21, 2009. 6:02 AMpolse300 says:
this is batch file..
Jan 12, 2009. 6:48 AMdmur654 says:
to stop u can just hit x at the top right of cmd if u have an echo on it or else "ctrl+c" to stop the batch...
Oct 13, 2008. 3:59 PMKaelessin says:
heh how about using a memory leak or something?! >:)
Dec 8, 2008. 9:52 PMArbitror says:
Memory leak, heard that before, but its slipped my mind...
Definition?
Example?
Dec 8, 2008. 9:54 PMArbitror says:
Wait, that's a pun! But I actually want to see an example!
Dec 9, 2008. 3:27 AMPKM says:
You can't cause memory leaks with batch programs. With a suitably low level language like C a memory leak is where you say "put this memory aside for me, I want to use it", then forget to ever say "I'm done with this memory, you can have it back" so your program keeps taking up more memory. A deliberate memory leak would make this worthless Instructable... still worthless and a little more irritating, but would at least involve a small modicum of programming skill.
Dec 9, 2008. 5:16 PMArbitror says:
I didn't mean in batch, I just meant in general. Thanks for the definition though!
Dec 9, 2008. 4:05 AMKaelessin says:
erm yeah i wasn't very clear but i intended to mention using a more useful language . . .you should be able to do this with any language without automatic garbage collection though no?
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:MattHacks
I like to Hack and Program!
