iImage Information
Pillow-top beds are great and all, but over time one's butt has a tendency to mash down the top layer of foam padding. This curvy bed might be nice for a back-sleeper, but as a stomach-sleeper I was getting pretty tired of waking up with a stiff back. Hence, I performed an autopsy on my bed to determine if it was in fact just the top surface or a deeper cause. As it turns out it is quite simple to mod a bed of this type for optimal sleeping performance. The following steps will show you how to hack your own bed for maximum sleepability.
Step 1Stab it.
iImage Information
Examine the mattress. The mattress is made of several layers of foam and springs and it is all wrapped up with a soft looking textile, kind of like a burrito. The pillow-top layer is a bunch of foam quilted together and then sewn onto the wrapping material. It turns out that you can pull this wrapping away from the underlying foam.
So the first step is to pull the wrapper off the bed and stab it with a nice sharp knife. Be sure to cut below the pillow-top so you will be able to remove it as a whole piece. Also, be sure not to stab your foam, it may be very soft.
Also, does the pink lettering say "CHILD" or "(141LD)"?
L
