iImage Information
How to hack a USB keyboard or any keyboard for that matter. Send inputs into the computer without a pesky microcontroller.
Step 1Open up the keyboard
iImage Information
Open up the case. You can use a screwdriver or an any ridiculous looking multi-purpose tool. Sometimes even after all the screws are removed the keyboard still won't open up. In this situation, don't worry, just forcefully pry the case apart with your screwdriver. It doesn't matter if you break the case. You don't really need it.
That video u mentioned on http://a.parsons.edu/~randy/video/typewriter.mov is down due of Inactivity. Please send new video and url please.
This was good tutorial :) i wanna see that video and i wanna try making own version of Typewriter perhaps :) Need motivation and wanna see that video :)
/ted
Basically I'm using this hack to control an electronic drum set that I'm trying to make using the alphabet characters as triggers. The program I'm going to use seems to allow simultaneous hits.
My question: How do I wire it so that one button will trigger two different letters at the same time? My thinking is that if I wire two letters together, the board will be confused, this sending the wrong signal or no signal at all.
Can anyone explain what should happen? I'd like to address this before I try to build this and see that it doesn't work.
Thanks!
I use a music playing program on my pc called 'HappyEO'. It let's me press mulitple keys at the same time to play chords etc.
On a related note. When I the program on some computers I get a delay when i press a key. I was using it on my 7 year old computer running XP and it was instant. When i installed it on my friends pc with windows 7 I got the delay from when I pressed a key to hearing the note. same on laptops running Vista and recently on a laptop runnin XP. Do you think it's something to do with the secrurity software that might be on the pc's?
Thanks for giving me the need to keep looking for an answer!
Also, will a piezo attached to these pins work and will it produce two "keystrokes" for each hit as I've seen mentioned?
Thanks for the great instructions, and thanks to all who contribute and answer all the questions out here.
http://www.instructables.com/id/Typewriter-Computer-Keyboard/
Also, I'm trying to build one with one simple function...I want to make a big "Easy" button, or something like an "Easy" button send a space bar input. Would I follow the steps in this instructable, connect the "free" side of the wires from the modded keyboard controller to a prototype breadboard, and connect the leads of the Easy button to the breadboard where the wires from the keyboard connect?
So basically keyboard controller -> Prototype breadboard <-Easy button...?
Thanks so much!
Put one of the layers on a image scanner, scan it and fill the lines with different colors using the fill tool. Took me only 30 minutes to get the entire pin layout
My latest attempt was going to be a large MAME machine, but I was scratching my head on just how to deal with the inputs. Trying to stick a full-blown keyboard into the device just to have the buttons press the keys seemed a bit hacky at best. This is awesome. Now I'm just TRYING to figure out what all I want to make with my extra keyboards. I even have some wireless keyboards that I could see using to do some fun stuff with.
I was going to build a MAME cabinet using it, but never got round to it.
very good instructable.
