3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacking a USB Keyboard
Step 6One step beyond!
One step beyond!
Once you have a hacked keyboard you can use it for a number of functions and attach a number of different types of switches.
You can build your own typewriter keyboard. Check the picture and video. It may not auto-load and it may take a long time to load when it does (it's around 20 MB), but here is the video of the typewriter:
http://a.parsons.edu/~randy/video/typewriter.mov
You can use a photocell as a switch (as seen in the picture and video).
You can hook it up to a capacitance sensor and use just about anything to trigger an event in a Flash movie.
You can hook it up to some floor switches and develop your own DDR game.
You can do more things than I could ever dream up.
17 comments
Aug 25, 2010. 6:18 PMI MAKE STUFF says:
another use of this is to add switches to flight sims such as fsx, fs2004 ect.
Feb 2, 2009. 8:19 AMavibank911 says:
how do you solder the wires without burning the PCB??
Jun 14, 2009. 9:30 AMAzayles says:
Use a soldering iron, not a blowtorch.
Sep 12, 2009. 8:04 AMGoodhart says:
Gee, looks like I'll never get to use my 100 A arc welder ever again.... ;-)
Sep 11, 2009. 8:02 AMmdgnys says:
Oh I have one of those!!!!!!!!!!!!!!!!!!!!
Sep 9, 2009. 7:38 PM1337pato says:
Burn
Sep 9, 2009. 11:36 AMDavidHasselhoff says:
ROFL
Jun 14, 2009. 2:03 PMATG says:
LOL
Sep 10, 2009. 1:19 PMChromatica says:
lmfao
Sep 11, 2009. 5:58 AMKasm279 says:
lol!
Sep 12, 2009. 2:55 AMrandom green dude says:
LMAO
Feb 3, 2009. 5:00 PM-henry- says:
It's nearly impossible to burn the PCB when you solder, unless your soldering iron is WAY to hot.
Feb 17, 2009. 10:47 AMSagar Gondaliya says:
i put mine at 800+ degrees. is that bad?
Jan 7, 2010. 1:32 PMMalfurious says:
Using a material that has a melting point above 800F is brazing. Most likely, your soldering iron isn't designed to sustain those high temperatures. Are you using a material that requires your gun to be that hot?!?
Jan 7, 2010. 4:24 PM-henry- says:
 You realize that you responded to a post almost 1 year old
FYI
Sep 11, 2009. 9:08 AMWilderLust says:
Wow! you don't need it so hot. most of the work i do is under 300 deg. sometimes when i have larger cables or large metal parts to solder i go up farther but 800 is really high for electronics. your element will last longer at lower temps too and you will not fry so many things. the solder i use melts around 250 deg. i would recommend you cool things down for electronics! cheers :-)
Sep 12, 2009. 10:45 AMSagar Gondaliya says:
Ty. i only keep it hso hot so i can get done faster :| Thanks for the warning. im gonna make it so it cant get past 450
Feb 17, 2009. 4:11 PM-henry- says:
that's fine, anywhere from 700-900 degrees (F) is fine for soldering,
Feb 18, 2009. 3:03 PMSagar Gondaliya says:
thnx cuz sometimes my dad gets mad when i put it that high. just wanted to make sure that i wouldnt damage anything. thnx again
Sep 4, 2009. 4:38 PMthecheatscalc says:
by the way, what type of solder are you using? electronics solder is usually 350-400 degrees Fahrenheit...
Sep 11, 2009. 3:47 PMBFeely says:
Lead free melts at a higher temperature, around 420 to 440 degrees F.
Sep 12, 2009. 2:05 AMFieldownage says:
Basic lead is best at 300-360.
Sep 12, 2009. 4:29 AMosama_ says:
Interfacing a keybord with a microcontroller is a good idea. Thanks a lot for the link.
Sep 11, 2009. 5:03 AMdjhusi says:
Lolz I made a bot (a cheating device) for an MMORPG a couple of years ago and used the same technique. It is really easy to evade Game Guard or PB this way :)
Sep 9, 2009. 8:08 PMlegionlabs says:
I had a broken capacitive keyboard (not a very common thing) and found that shorting the relevant pins on the IC did nothing. It was required that I short them across a small ceramic disk capacitor (value not so important). Also, if you take an N2222 transistor, the human body conducts enough current @ 9v to push it into switching mode. Put the transistor between two areas of interest on the keyboard matrix IC, and you have a quick and dirty touch switch. I've tried this, it works well and responds faster than a physical switch... a good mod for all you FPS types?
Jul 4, 2008. 4:41 AMshdhwk says:
OK...So would this work for putting 2 keyboards together for a dual boxing gaming system using 2 identical USB keyboards? I've been toying with the idea for a while now, and I my have to give it a try, but I would like to hear if anyone has tried or succeeded at this.
Sep 8, 2009. 1:44 PMhishealer says:
So are you that tank/whm team I keep seeing in the Dunes? \>.</
Sep 4, 2009. 6:42 PMfreasafan13 says:
unless you use all the keys then you can just use one and calibrate it so that you only use the keys on each controller
Jul 22, 2009. 8:16 PMdanton721 says:
I think it go work,cause PS/2 and USB keyoards can work together,but in the game,you will have to change the comands,Example:One player stay on keyboar arows,the other in W,S,D,A I think you can undesrtand i wrote,cuz my native language is Portuguese ;D
Sep 8, 2009. 9:01 AMmitchell12 says:
Many people use this to make push buttons and switches for flight sims and racing sims. Neat ible
Aug 26, 2008. 1:34 PMroystonlodge says:
More ideas for whacky applications: - Electronic Whack-A-Mole game. - "Buzz-in" devices for trivia games like You Don't Know Jack. - A cheap way to convert old Atari joysticks and NES gampads for use on a PC. I wonder how hard it would be to keep the keyboard relatively intact, but just remap the F keys to other devices, like an old joystick. That way I'd still have my keyboard but I'd be able to use my old joystick as well.
Apr 2, 2007. 11:25 AMJoeBees says:
I've made a DDR board out of a keyboard I hacked in the same way you described. Works well. Free DDR. (except materials cost) I'll have to make an instructable about it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2350
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
