3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacking the Xbox 360 controller
Step 3Theres two traces for each button! WTF?
The switching is done differently on the 360 controller. There will be two traces for each button. We can't just ground/pullup one trace to make the X or Y function happen.
The trace on the left of the button will transmit a signal to the trace on the right of the button. This is important. As discussed before, the optocoupler is unidirectional. Do you see what I mean?
So for a common 6 pin photocoupler, such as the 4n27, pin 5 is the phototransistor collector. This must attach to the left trace for the respective button. Pin 4 is the phototransistor emittor. This has to be connected to the trace to the right of the button.
Now pin 1 of the coupler is the anode of the light emitting diode that is hidden inside of the chip. This means we can attach pin 1 to our positive rail.
Pin 2 is the cathode. So we can attach this to our chip... But wait a minute. If we won't put a resistor in there, somewhere, we will burn out the diode or our microcontroller.
Pin 3 is normally unused, so we can solder a small smt resistor between pin 2 and pin 3. Then we can attach out microcontroller output pin to pin 3 of the coupler.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:klee27x
