3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacking your Digg Button with a Removable Interface Cable
Step 10Attach Wires to the D-Sub Connector
The last step of construction is to attach wires from the pin header to the D-Sub. If you installed the pin sockets, all you have to do is slide them over the protruding wires on the D-Sub. If you're soldering directly, then you just match up wires and solder them.
Hopefully, by now, the epoxy has dried enough to handle. If not, take a short break and come back. I'll be less messy that way.
Using our lettering scheme from before the wire are connected as follows:
Pin-Header "A" = not connected
Pin-Header "B" = D-Sub Pin 20
Pin-Header "C" = D-Sub Pin 2 (resistor)
Pin-Header "D" = D-Sub Pin 11
Pin-Header "E" = D-Sub Pin 5 (resistor)
Pin-Header "F" = D-Sub Pin 4 (resistor)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bobber
