Step 11Connect Everything Up
The basic process is:
- Clip the stick on one side to the back of the Digg Button board over the solder pads.
- Slide the connector between the stick and the solder pads making sure to line the pins and pads up
- Clip the other side of the stick to apply pressure on the connector
Once the board is connected, plug the D-Sub connector into either your cable or parallel port.
As you might expect, if anything begins to smoke (highly unlikely), unplug things fast!
Add Comment
