Step 8Epoxy the Header Connector Wires
I waited until the epoxy began to thicken just a little (but not too long!) then scooped some up with the toothpick and spread it over the wires and connected pins. Make sure not to get epoxy on the bare end of the pins or making a connection with the circuit board will be difficult. The epoxy will want to drip off the connector, but by cleverly turning the connector over as the epoxy begins to sag, you can keep it more-or-less in place. As the epoxy begins to harden, it's easier to keep it in place until it finally sets and you can stop worrying about it. Set aside the cable assembly until the glue is finished setting.
addendum: I recently made a new connector using epoxy putty rather than liquid epoxy. This worked quite well and was a bit easier to manage since the epoxy wasn't trying to drip off while it was curing. However, the putty is opaque, so I lost the delightful see-through effect.
Add Comment
