3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hacksaw and Cordless Drill Lathe (Sort of...)
I had a milled carbon steel tube that I wanted to modify by cutting a "cone" off the end, but wasn't sure how to make an accurate, square cut as I could not use a tubing cutter. I also did not want to pay someone to cut the cone. My "on-the-fly" method using a hacksaw and cordless drill worked surprisingly well and quickly, with very little flash and few burs.
Step 1Chuck it up!
Chuck it up!
Find "something" to use to chuck your tube/pipe/etc. in your drill.
In my case, a 7/16-inch socket with a hex base made for hand drills had the perfect exterior diameter for a really tight friction fit with the interior diameter of the tube.
Sorry for the mixed-up photo timeline. I really came up with this quickly and was surprised it worked as well as it did and I didn't think to take pics until well into the project.
13 comments
Jan 22, 2011. 1:49 PMglorybe says:
You will really want one of the grit edged saw blades. If the metal is hardened you also will need to keep it very cool or it will not be hardened after the cut. Also if failure of the part might result in injury the part should not be altered. For example making a drill collar that spins at speed can lead to serious problems if the strength or brittle qualities of the material are altered in any way.
It is great that you are trying new things and sharing them with others. It is simply this world is more complex than it sometimes appears. I am reminded of the chrome plating shop that was sued for a fatal accident after some hobbyist sent in some bolts for chrome plating that were taken from a washing machine. They were somehow used in an area of a car that looked good with those chrome bolts but when the bolts failed due to the plating a fatal wreck was the consequence. When we handle a piece of metal it is hard to know how that metal may be used down the road.
Dec 26, 2009. 4:43 PMTool Using Animal says:
Mini 14 Flash Suppressor???
Dec 7, 2007. 6:03 PMJohn Smith says:
Ha, I do this all the time, but using my Dremel. It works wonders. Nice instructable!
May 17, 2008. 5:27 AMdunnos says:
seriously? then i have some questions 1. wont it go to fast? 2. could you make an instructable im to tired to think of something 3. how
May 17, 2008. 6:48 PMJohn Smith says:
haha, i meant that instead of the hacksaw i use the dremel. Everything else is the same
May 18, 2008. 1:42 AMdunnos says:
oh darn i hoped on a dremel lathe :P
May 18, 2008. 8:13 AMJohn Smith says:
haha if you want a cheap wood lathe, look at Grizzly industrial's drill lathe. dont have a link now, but look through them. They're not too overpriced.
Dec 7, 2007. 9:36 PMShark500 says:
I've been doing this for years. What where you cutting? looks cool.
Dec 7, 2007. 9:40 PMShark500 says:
you can also use metal bars in the drill against a grinder or file to make sharp points or curved edges.
Dec 7, 2007. 7:40 PMT3h_Muffinator says:
Just did this today, but with plastic gears and some brass tubing.
A skill everyone should know =)
Dec 7, 2007. 6:06 PMGorillazMiko says:
cool instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:justmakeme!
