Hairstyles for Hair Sticks
 by medellia_4
Featured
Here are several hairstyles, gathered from my own experience as well as various places on the web, that demonstrate different ways hair sticks can be used.
Hair sticks are fun, and actually pretty easy to use. The best way to insert a hair stick is to push it gently into your hair and sort of weave it up and down as you draw it through your style (bun, braid, ponytail, etc.) so as to anchor it. Don't be afraid to push the stick all the way down to your scalp; it makes the hold even more secure.
Hopefully I haven't missed any steps, and everything is clear enough to follow. The pictures were all taken in my kitchen by my friend, and they all feature my hair. But don't get too excited--it has since been cut.
Step 1: My Favorite Bun (Cinnamon Bun Variation)
I start putting my hair in this bun as soon as it's long enough; adding hair sticks makes it look much more elegant and keeps it very stable. Just a note--my hair is quite long in these photos (just past my butt), so my finished product may look kind of different from what you do with your hair. But you DON'T need hair as long as this to successfully use hair sticks--if you can put your hair up, chances are you can use them.
On to the bun!
1. Gather hair together at crown; twist entire length.
2. Coil entire length of hair, putting each successive layer beneath the previous one, so that you end with a column of hair (the height of which varies depending on the length of your hair).
3. Take top coil of column and pull out, pulling it down so that it surrounds the column, flattening the entire bun. Tuck ends. Insert one or two hair sticks to secure bun.
Step 2: Cinnamon Bun
2. Coil entire length of hair, starting with a small coil and surrounding it with each successive coil, keeping the bun flat to the head.
3. Tuck ends, secure with hair tie. Secure the rest of the bun with one or two hair sticks.
Step 3: Chinese Bun
1. Gather hair into ponytail at crown. Secure with hair tie of choice.
2. Insert hair stick through gathered hair, behind hair tie.
3. Separate hair into two equal parts.
4. Wind each piece around hair tie, behind hair stick. Tuck ends in, or secure with hair clips/pins.
Step 4: Chinese Braided Bun
1. Gather hair into ponytail at crown. Secure with hair tie of choice. (This can also be done without securing with a hair tie; just make two braids at the back of your head, spaced as closely together as possible.)
2. Divide hair into two equal parts; braid each part so that you end up with two braids.
3. Insert hair stick through gathered hair, behind hair tie.
4. Wind each braid around hair tie, behind hair stick. Tuck in ends, or secure with hair clips/pins.
Step 5: Sock Bun
1. Clip a small hole in a sock (the size of the sock bun will be determined by the size of the sock) and roll from the toes up.
2. Gather hair high up on head, around the crown, and secure with ponytail holder.
3. Twist hair into a rope and slide sock up the length, pushing it against the hair tie. Let hair untwist.
4. Lean over; spread hair back over the sock, covering it entirely. Use another ponytail holder to secure spread-out hair over the sock.
5. Stand up straight; gently push hair down so that the remainder (if you have a remainder) spreads out under the newly-created sock bun. Do whatever you wish with this; braid and twist around bun, simply twist around bun, let hang. At any point, a hair stick can be used to increase the stability of the bun or for decoration.
Step 6: Figure-8 Bun
1. Gather hair at crown. If you desire, secure with a ponytail holder.
3. Grasp top-most coil. Pull out and up, laying flat on top of the rest of your head. The resulting look should resemble a figure 8.
4. Secure bun with hair stick(s).
Step 7: Hair Knot
(This is a small bun with a ponytail coming out.)
1. Gather hair at crown. Twist entire length and bring over and around, actually tying your hair in a knot.
2. Let the part of the knot coming out hang out loosely. Secure knot with one or two hair sticks.
3. Let ends hang loosely, or braid.
Step 8: Dutch Braid Bun
1. Plait your hair Dutch style (very similar to French style; instead of bringing pieces over, bring them under.)
2. Gather braid and coil it into a bun.
3. Secure with one or two hair sticks.
Step 9: Half-Bun
In this style, a small bun is created by gathering the top part of your hair and letting the rest hang down. The final look of this style, and of course the size of the bun, is greatly determined by the length and thickness of your hair.
1. Gather top half of hair into bun style of choice.
2. Secure with hair stick.
1-40 of 47Next »
musicalsoul says: May 5, 2013. 11:04 AM
Lovely! You have beautiful hair and I love the styles:)
Mauigerbil says: Aug 29, 2012. 8:09 PM
Awesome! My friend Sam has reeeaaalllyy long hair (beyond her hips) and she would love this!
Judith756 says: Mar 9, 2012. 6:58 PM
I have been using "hairsticks" for 30 years now. Of course mine are all chopsticks that came decorated and I added charms on the ends or are plain...lol. Love that you did the pictures, but consider a video. I have tried to show my younger friends how to twist their hair, unfortunately I am left handed and they are right. I seem to confuse them. You did a great job with the pics, but a bit more would be wonderful.
Thanks for posting your ible.
black_lily says: Jan 13, 2012. 2:03 AM
I have natural curly hair, so most of these are useless for me, but i recommended to a friend who was looking for good instruction on hairstyles with hairsticks and she loved it. Great instructions :D
ariadani says: Jul 23, 2011. 7:20 AM
Very pretty. I have long hair, too, so it's nice to see different variations than my usual "stick it up in a bun with a stick" style :)
josieisacoolcat says: Jul 12, 2011. 8:17 PM
You have beautiful hair!
gswhite1959 says: Dec 13, 2010. 5:21 AM
What do you use to keep your hair shiny and what do you shampoo it with?
Thanks, I want long hair like yours. Thanks
alexandraw99 says: Nov 17, 2010. 5:35 PM
heyy i was wondering if u could do a vidoe about treating your hair and im not a freak but your hair looks amazing and im trying to grow my hair out so i was just wondering thanks great job by the way
panvirgo says: Nov 13, 2010. 10:20 PM
BEAUTIFUL HAIR, BEST FOR OCCASION CINNABON BUN HAIRSTYLE.
Screamo says: Sep 26, 2010. 10:59 PM
Chop stickeys :D
SpinninJenny says: Jun 1, 2010. 1:22 PM
I use hair stick for special occasions but use 3 inch long hair pins or claw clips the rest of the time. I usually just wind it around like the cinnamon bun. It's really exciting to find something new to do with my long hair!
I'm also excited to see your hair sticks! I don't know how to get in tough with your aunt and find out if she could make some for me. Can you have her get in touch with me?
Thanks!
Trollgunn says: Mar 21, 2010. 1:22 PM
This is gorgeous. Too bad I just had my hair bobbed!
tonic4 says: Feb 27, 2010. 8:06 AM
Love it! I'm starting to grow my hair out again but was worried about what different styles I would be limited to. Now there is hope.
MeowKitty49 says: Nov 23, 2009. 1:08 PM
(removed by author or community request)
medellia_4 (author) in reply to MeowKitty49Nov 23, 2009. 3:20 PM
You're very welcome! I'm glad I was able to help you out. ^_^
starshipminivan says: Jul 2, 2009. 8:34 PM
Thank you for the instructions on the sock bun! I looked everywhere for a "bun doughnut" for my daughter's highland dance hair style and never did find one.. A sock is perfect substitute!! I like all of the great pictures on all of the steps. You gave really good instructions. Thank you so much for posting!
medellia_4 (author) in reply to starshipminivanOct 26, 2009. 6:17 PM
I'm ridiculously late in replying, but you're welcome! I'm glad you were able to find what you needed.
wheedee says: Jul 4, 2009. 5:51 PM
Even thought it's not a figure 8, it's a very nice treble clef XD
medellia_4 (author) in reply to wheedeeOct 26, 2009. 6:16 PM
You posted this a while ago, but still, thanks, lol.
EarlyMusicDiva says: Aug 7, 2009. 7:30 PM
I was wondering what you do with the ends. It sort of looks as if you tuck them under the outermost coil before putting in the sticks? Is there a trick to making them stay underneath?
medellia_4 (author) in reply to EarlyMusicDivaOct 26, 2009. 6:16 PM
You posted this a while ago--sorry I haven't replied! I would leave a length of about a few inches and then yes, tuck them underneath the coils. I think leaving it a bit long helps the ends stay tucked.
blackchibi says: Oct 8, 2009. 12:47 PM
I tried it on my medium lenght hair and it turned out great. thanks for the inst. :)
medellia_4 (author) in reply to blackchibiOct 26, 2009. 6:14 PM
You're welcome! I'm glad you were able to use it with your length.
Nettiemac says: Oct 24, 2009. 8:14 PM
I used a pair of clean chopsticks in my hair yesterday, and got lots of compliments from people about how it looked.  Especially from my youngest son.  He thought I looked beautiful and Japanese.  grin.
Thanks for showing how to wear these - it gives me a more adult option than just a ponytail.
medellia_4 (author) in reply to NettiemacOct 26, 2009. 6:14 PM
You're welcome--it's amazing what a difference a pair of sticks can make, isn't it?
planethalia says: Oct 26, 2009. 5:45 PM
Ditto to Mama29... I'm so sick of ponytails and buns I was pretty close to make the great hack.... this gives me more options for awhile!
medellia_4 (author) in reply to planethaliaOct 26, 2009. 6:14 PM
I'm glad you liked it!
hopenui says: Jul 27, 2009. 8:16 AM
I'm not personally interested in this, but seeing my gf trying to do this and usually fail is funny
lindsy says: Jul 5, 2009. 1:08 PM
the "sock hair bun" is how we had to do our hair in the Marines... Except NONE could be hanging down.. It my favorite "clean looking" bun :)
tannpopo says: Jul 2, 2009. 11:19 PM
It's great to learn this. by the way,your hair is so long.
veeisme says: Apr 20, 2009. 11:07 AM
I love this one, it's the first bun I've ever tried that I was able to wear until it went droopy of its own volition without it giving me a headache!
XkytsuneX says: Mar 31, 2009. 9:44 PM
Lovely styles! I want to try the sock bun style! One thing is bugging me, though... the crown is much closer to the hairline than where you indicate in your photographs. It is defined as the top-most part of the head, and I think of it as the highest point of the forehead, right at the hairline.
Maureclaire says: Mar 12, 2009. 4:19 PM
Love them ! You have beautiful, thick hair ! My hair is so damn thin, you'd see that freakin' sock clear as can be ! Ugh !
Cayt says: Feb 1, 2009. 1:51 PM
Wonderful guide! =D Even with my relatively shorter hair (just a few inches past my shoulders) I can still use a few of the styles you've listed. Braided stuff tends to use up too much hair, but the simpler buns work just fine! And I may just be endlessly jealous of your beautiful long hair. XD<br/>
LadyLonghair says: Jan 19, 2009. 3:42 PM
Thank you so much for these cool instructions! My hair is nearing knee length and these updo's will be a joy to play with.
lovelypinkfairy says: Jan 15, 2009. 11:49 AM
Wow !!!! great instructable... You have lovely long hair and I'm surely gonna try these hair styles.. I hope you come up with few more like this... -Pink
thricecursed says: Jan 15, 2009. 8:38 AM
Fantastic Instructable! My daughter and I are going to have a blast trying these out! Thanks for sharing. :)
staralee says: Dec 15, 2008. 8:00 AM
This is an awesome instructable, Thank you very much for putting it on here. I am excited to try these styles, My favorite is the chinese bun so far, very neat!
mama29 says: Aug 18, 2008. 12:55 AM
Well done. I am so happy to have something else I can do with my long hair for work. I need to have it pulled back but get sick of the same bun and plain braid. Thanks for postign this!
TheChemist says: Aug 9, 2008. 1:14 AM
awesome! -Gracie
1-40 of 47Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
