Step 5The Comedian: Suspenders
-paper for template
-denim-like fabric
-black fabric dye
-1" webbing strap
-D-ring x 2
-plastic adjustable thingy x 2
-smiley pin
Directions:
1- A paper template was drawn and traced four times on the fabric. Four rectangles of fabric were also measured to hold the strap against the suspender pads.
2- The pieces were sewn together to create the suspender pads and dyed black. Once dry, short lengths of straps were cut and glued on each pad to secure the D-rings to them.
DAISNAID: It is recommended to sew the lengths of strap to two rectangles before sewing them onto the pads. I just forgot to do it so I managed with glue.
3- The rest is pretty straight-forward. A length of strap is weaved through each suspender pad. The back end is sewn to create a loop through which a belt will pass. The front end is sewn to a plastic thingy in such a way to allow the front loop to be adjusted. A "cross-strap" looped at both ends is secured with velcro a short distance from the suspender pads. These will prevent the suspenders from sliding over the shoulder and falling off once the shoulder pads are attached.
4- Finish off by adding the smiley pin to the left D-ring.
Add Comment
