Halloween Basket
238
Published
Introduction: Halloween Basket
About: In love with traveling, food, floral design, home interiors, and crafting.
Every Halloween is a new adventure! With different costumes, different candies, but the excitement is there every year.
With this craft you´ll be able to make a Halloween basket that matches the costume, and you could make a different one every year. Maybe that could be our new tradition, and while carving Jack´o lanterns you can also carve your candy basket.
Step 1: Gather Your Materials
Glue gun
Battery operated tea light
Green pipe cleaner
Green felt
Tulle
Scissors
Black permanent marker
X-acto knife
Spray paint and primer
Big cardboard container. Like those that are used for packing powdered beverages (milk, iced tea, gatorade, formula)
Step 2: Draw
With the marker draw the design you want. There are many jack o´ lantern patterns, you can print one of those or make your own character.
Step 3: Cut
With the x-acto knife cut the design you just made.
Step 4: Primer
Apply one or two coats of primer. Wait enough time between each coat.
Step 5: Paint
Then apply the paint. If your paint is of good quality, and you used primer, only one coat will be enough.
Step 6: Tulle
Cut the tulle and glue it inside covering the holes. Because we don´t want any candies to fall down.
Step 7: Lid
Cut 1/3 of the lid.
Glue the tea light to the lid.
Step 8: Glue the Lid
Glue the lid on place, the tealight will be inside the can but you can still reach it to turn it on and off.
Step 9: Cover the Lid
Use the green felt to cover the lid, cut and stick it with hot glue.
Step 10: Pipe Cleaner
The little details are important, that will make your project stand out. So twist the pipe cleaner around a pencil. Glue it at the top of the lid.
Step 11: Handle
I tied two black pipecleaners together, then pierced the cardboard and tied the pipe cleaner.
Step 12: Trick or Treat?
It´s ready to be filled with candies. Trick or treat?
    • Backpack Challenge
      Backpack Challenge
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
