loading
Step 2: Gathering materials and measuring the yard
Before you begin making your fence, you need to measure the area you want the fence to go. I have a rather big front yard so running across the front and down the sides, I came up with 190' of fencing, or twenty three 8' panels and one 6' gate panel. Your yard haunt will differ. You may decide you want 10' panels vs. 8'. That is up to you and may be dictated on how much room you have and your dimensions. Say you have a yard with 20' before a sidewalk and 20' after the sidewalk. Two panels 10' per side may be warranted .
Once you find out how much fencing you will need, the next step is to gather the materials. Below is a material list.
For one 8' fence panel:
>>> (3) 10' pieces of PVC 1/2" diameter. I chose to use the gray electrical PVC called JM
             Eagle as it was 92 cents a stick vs $1.46 for the white stuff.
>>>(3) Furring strips 8' long. You can use 1x2 or 2x2. I chose the 2x2 for added strength
>>> (1) 10' piece of JM Eagle 2" PVC
>>> (2) pieces of 1/2" rebar 4 foot long or 2 four foot T posts from someplace like Home Depot.
>>> (9) 3/4" plastic fence finials. You can pick them up online at sites such as
            mcfrugal.com With shipping, they came out to about 30 cents each.
>>> Sand paper, 120 to 180 grit
>>> White kilz primer. The cheapest primer that stuck well
>>> Exterior Black latex paint. I chose Behr and it was $19.95 a gallon with $5 back in the
           mail making it under $15 in 8 to 10 weeks of course
>>> (1) box of 1 1/4" screws
>>> (1) box of 7/16" panhead screws
Tools needed:
>>>Power drill
>>>7/8" spade bit
>>>Drill press ( not needed but really handy)
>>>Phillips bit to drive screws
>>>Paint brush, paint roller, paint pan
>>>Rubber gloves
>>>An old sock ( to paint with)
>>>Heat gun ( real use to strip paint from a house)
>>> Sledge hammer or post driver ( for rebar stakes)
>>> PVC cutter ( about 12 dollars at a home improvement store and will save time and headache)
>>> A saw to cut the 2" PVC as the cutter only goes to 1 1/4"
>>> Tape, duct or electrical. You will need it for a few things.
>>> Pocket knife
Next recruit help. It takes much more time than you think to create a fence.
<p>great instructions. A couple things I did. I used 5/8 dowels to connect the 5/8 finials. I used great stuff foam insulation in the 2 inch tube to stabilize it .Thanks for the great idea. </p>
<p>Glad it worked out for you. Good luck using it for years to come. This is my 5th year and it is still going strong.</p>
Thanks for your instructable Haunted Spider. My son and I completed our Cemetery Fence this weekend. The only thing we did different was to use 3/8&quot; rebar to support the fence ( 1 piece of rebar in each of the long posts, so two per section). Your instructions were spot on. Here's a picture of our completed work. <br> <br>Thanks again, <br>Flying Conch <br>
The fence looks great. I like the aged rust look. What technique did you end up using for that? I never found one I really liked so I left it black.
We used a can of rust colored primer in a spray can. Started light and continued to add. This afternoon, I'm headed down to the canal to get some Spanish Moss.
Wonderful fence. I built it 2 years ago from your directions and its still going strong. It's seems to get better with age and gets the rustic look. I can't wait to put it up his year.
Glad it is still working out for you. This will be my 4th year putting up the fence and it still works great for me as well. I have actually added some LED lamps to a few of the posts leading to my drive and sidewalk. But otherwise it is unchanged and still holding. Good luck with the set up this year.
Holy Crap.<br>Beyond awesome. This is on my list of things to do in my life when I can quit being so lazy. (and I have a place to store the thing). Thanks a ton for posting this and all the great tips. (I found this looking for PVC painting tips.
Awesome instructable! With all the detail provided, I was able to make my own fence (which turned out as good as I'd hoped it would). Your helpful tips were appreciated and definitely made things easier for me - thanks!!
I am quite impressed by the level of detail and information you provided. Thank you for taking the time to explain your successes (and possible failures). All the best in the contest!
Thanks, I tried to explain the project as best I could. I found that searching online, I only ever got pieces of information on how to create a fence. No one showed the steps or why you need to do something a certain way. Hopefully this will give people a better understanding on how to go from start to finish.
Nice work! That's dedication. Your use of multiple jigs really must have tremendously sped up the process (which was still quite long, I'm sure!).<br><br>Absolutely, you must add this to the Halloween contest. Once you've done so, I'll cast my vote.
Thanks for the compliment. It did take a while to make but not too long over all. If I had good weather, the whole thing could be done in about 2 weeks. You have to let paint dry and you just get too burnt out working hours on end. With a volunteer crew of 4 or 5, it would go fast.
About This Instructable
109,796views
85favorites
License:
Bio: I work as a safety and health specialist for the NEORSD (Sewer district). I don't get to touch a tool on the job as ... More »
More by Haunted Spider:Toddler Tool Harness Giant Mousetrap Melted Icecream cupcakes
Add instructable to:
