Introduction: Halloween DIY Project - How to Make a Pair of Golden Wire Wrapped Skull Earrings With Pink Jade Bead
Picture of Halloween DIY Project - How to Make a Pair of Golden Wire Wrapped Skull Earrings With Pink Jade Bead
This article is about a pair of golden wire wrapped skull earrings for Halloween. Hope you like the skull earrings. Just give it a try with the tutorial below.
Step 1: Materials and Tools Needed in DIY the Wire Wrapped Skull Earrings:
Picture of Materials and Tools Needed in DIY the Wire Wrapped Skull Earrings:
8mm Mashan Jade Beads
0.8mm Golden Copper Wire
0.5mm Golden Copper Wire
Golden Earring Hooks
Needle Nose Plier
Round Nose Plier
Diagonal Plier
Step 2: Make the First Part of the Wire Wrapped Skull Earrings
Picture of Make the First Part of the Wire Wrapped Skull Earrings
1st, cut a piece of 0.8mm golden copper wire and twist the middle part(as shown in the picture);
2nd, thread a pink jade bead to the left wire and the right wire respectively (as shown in the picture);
3rd, cut a piece of 0.5mm golden copper wire and wrap it around the top part of the left pink jade bead (as shown in the picture);
4th, make a semi-circle around the pink jade bead. Then, wrap the copper wire around the right part of the same pink jade bead (as shown in the picture).
Step 3: Make the Second Part of the Wire Wrapped Skull Earrings
Picture of Make the Second Part of the Wire Wrapped Skull Earrings
1st, wrap the copper wire around the bottom part of the right pink jade bead (as shown in the picture);
2nd, similarly, make a semi-circle around the right pink jade bead. Then, wrap the copper wire around the right part of the same pink jade bead (as shown in the picture);
3rd, continue to wrap the copper wire around the pink jade beads(as shown in the picture).
Step 4: Make the Third Part of the Wire Wrapped Skull Earrings
Picture of Make the Third Part of the Wire Wrapped Skull Earrings
1st, continue to wrap the copper wire around the pink jade beads (as shown in the picture);
2nd, wrap the right 0.8mm copper wire around the left 0.8mm copper wire. Then, cut off the excess 0.8mm copper wire (as shown in the picture);
3rd, make a hoop with the left 0.8mm copper wire. Then, cut off the excess 0.8mm copper wire (as shown in the picture);
4th, add a golden earring hoop to the top of the wire wrapped skull earring (as shown in the picture);
5th, refer to the above steps to make the other pair of the wire wrapped skull earrings.
Step 5: Here Is the Final Look of the Wire Wrapped Skull Earrings.
Picture of Here Is the Final Look of the Wire Wrapped Skull Earrings.
Do you like this golden wire wrapped skull earrings with pink jade beads? Just with some wires, jade beads and earring hooks, you can also make the golden wire wrapped skull earrings. Come on and have a nice try!
Simran Sharma (author)2016-10-12
Nice
DasiyD (author)Simran Sharma2016-10-12
Thank you, dear!
DIY Hacks and How Tos (author)2016-10-11
That design could also be easily modified to be an alien.
Interesting idea~
About This Instructable
731views
22favorites
License:
Bio: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are ... More »
More by DasiyD:Easy Bracelet Tutorial – How to Make a Wire Wrapped Bracelet With Crackle Glass Bead DecoratedPandaHall Tutorial on How to Make a Chic Seed Bead Choker NecklaceEasy Necklace Design – How to Make a 2-Strand Flower Bead Tassel Necklace
Add instructable to:
