Halloween Funeral Wreath
3,698
72
Posted in HomeHalloween
Introduction: Halloween Funeral Wreath
I make a lot of things with silk flowers and sometimes end up with extras.  I also end up with lots of loose leaves and naked stems. Here's a quick and easy way to turn those leftover supplies into a wreath fit for the dead.
SUPPLIES:
* 12-18 assorted silk flowers
* black spray paint
* drop cloth (optional)
* 2 silk flower stems
* wire & wire cutters
* black tulle (optional)
* hot glue gun and glue sticks
Step 1: Prepare Your Flowers
Remove the flowers and leaves from the stems.  Spread them out on a drop cloth and spray paint them black.  It's ok if some of the original color shows through...it adds to the creepiness and give the flowers a little bit of depth.  (Save the stems for later...you'll be using them to make the wreath form.)
Step 2: Create Your Wreath Form
Wire your flower stems together to make a circle.  Use 1 stem for a small wreath or 2 for a larger one.
Optional: Wrap your wreath form with black tulle and secure with a dot of hot glue at the end of the last wrap.  You could also paint the stems black when you are painting the flowers, but I like the tulle because it looks more finished and gives the hot glue a little something extra to grab on to.
Step 3: Add Leaves
Start gluing leaves all around the wreath form.  Keep leaves going in the same direction, layering end over end as you go.
Step 4: Add Flowers
Place the flowers around the wreath however you like and then glue them down.  Don't worry about the little glue strings that get all over the flowers...I purposely added extra to look like spiderwebs.
Step 5: Add Finishing Touches
Add a hint of color or some extra tulle.  (I had a few loose red petals that I decided to tuck in around a rose.)
Step 6: Hang and Enjoy!
Voila! You've just made something fabulous from scraps and would-be waste.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    2 Comments
    Wonderful! I especially love the add in of the red leaves. I really think that helps make the wreath pop!
    Thanks so much! I liked the red too...especially since it's so dark...keeps the whole things more creepy. :)
