3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halloween LED Jellyfish Costume
Step 3Mount the LED ropes to the basin
mount the LED ropes to the basin
I got a translucent (this is important, so light glows through it) basin from a pound shop (dollar store). it was about 50cm diameter, which is an ok size. for 18 tentacles.
I used hot glue to mount the battery end of the lights to the inside of the basin.
Use sandpaper to rough the surfaces first, then clean them thoroughly so it sticks better. people WILL pull your tentacles.
Leaving 5cm of plastic tube inside the basin. This will let you use a cable tie around this soft bit of the rope and leave everything nice and secure.
4 comments
Oct 17, 2007. 7:20 AMpedaleo says:
Can you please help me with details on doing the electrical connections. I'm not very good at this...
Feb 6, 2008. 7:40 PMPowerhouse says:
Pedaleo, I think I can help you. Just connect all the bottom terminals of the LED ropes with wires together then repeat with the top ones. The two end terminals go as follows: one goes to the switch and the other goes to the battery pack. Do not use a pushbutton switch.
Oct 18, 2007. 9:24 AMcrbnmnxide says:
I absolutely love this idea. :) Any idea how long the batteries in those necklaces last? I'm trying to decide if I just want to risk using batteries alone... I would probably just use it for Halloween, so would just need it for one night. Thanks!
Oct 26, 2008. 3:20 PMt_roy says:
Ok i hooded everything up right. But the batteries seem to get very hot.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:deadinsect
I am interested in the boundaries between engineering and art, with a slightly eco/nature vibe.
