3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halloween LED Jellyfish Costume
Step 6Control box and power supply
control box and power supply
this bit is optional. I used a switch with three positions : locks-on / neutral-off / temporary-on
you don't need this and wiring a simple on-off switch is fine.
I then hooked it all up to a 3 D-cell battery pack. I knew this was overkill, in terms of how much charge I'd need, but i was at a festival for a whole 4 days and didn't want to take any chances. you could probably get away for 3xC-cells or even 3xAA cells for a long night.
wiring
you put the 3 cells in series, to make 1.5V x 3 = 4.5V
then you put all the rope lights in parallel.
1 comment
Oct 29, 2007. 10:34 AMKapitan says:
I found that the button cells in the necklaces that I got were 1.6v each x 3 = 4.8v. This worked perfectly with the 4 x AA battery case with built-in power switch I found at RadioShack because I used NiMH rechargable AA's at 1.2v each (1.2 x 4 = 4.8v). The 4 AA's weren't too heavy mounted right on the helmet, but they didn't last very long. It was a good idea to have extra batteries with me.
Battery case I used: RadioShack
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:deadinsect
I am interested in the boundaries between engineering and art, with a slightly eco/nature vibe.
