3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halloween Pirate Cannon (and fog machine disguiser)
This Instructable describes the cannon I built to disguise the fog machine I use for my pirate-themed Halloween setup. I was built primarily out of standard 2 x 4 lumber and PVC/ABS plumbing, all available at your local big box hardware store. I apologize for the lack of interim pictures, but I did this project a while ago before I discovered Instructables.
Anyway, The main purpose of the cannon was to hide the fog machine in some context that made sense within the Pirate theme we've had for the last few years. Having the fog come out the cannon as though it were firing seemed like the obvious choice.
Step 1Designing the Plumbing
For me, most of the fun is in the planning and research. I sketched out some ideas that could be very easily built using simple 2 x 4 lumber. I then went to the local Home Depot and Lowes to see what was available in the plumbing department that would provide the right scale. Once I had all the sizes determined, I started modeling a solution. I'm an Industrial Designer (www.eikedesign.com) so I used Solidworks to determine the plumbing method. I decided to plumb a path from the fog machine exit up thru the bottom of the cannon to exit out the front. I used a large diameter pipe for the cannon body, a smaller diameter for the fog path, and a reducer on the front of the cannon to mate the 2 and to simulate the thick wall of my cannon.
29 comments
Oct 8, 2011. 11:09 AMlm45116 says:
how do you refill the fog machine
Oct 15, 2011. 4:51 PMlm45116 says:
Ok i get it thanks
Oct 18, 2010. 1:28 AM_biohazard_14 says:
cool whats the 3d programing software and iven the paint huh
Oct 8, 2010. 9:08 AMcablestein says:
Hiya, any info on the paint you used?
Aug 12, 2010. 5:18 PMneilh says:
Well done!
Jan 3, 2010. 11:01 AMmcrfan33393 says:
 what diameter is the inner pipe?
Nov 6, 2009. 3:57 AMrbbiggs says:
What size (diameter)  PVC pipe did you use, and how long of a piece?  Is the swivel made from 2 inch PVC?
Also, how wide and how long is the 2x4 base?
Thanks again for posting this, going to have some fun with my Kids !
Nov 8, 2009. 7:28 PMKiller~SafeCracker says:
Cool, you could make it "shoot" candy.
Nov 17, 2009. 4:23 PMrbbiggs says:
Shoot candy with the smoke, now that would be cool !!
Nov 17, 2009. 4:31 PMKiller~SafeCracker says:
Yup.
Nov 5, 2009. 2:26 PMrbbiggs says:
Great Job, looks easy to make too !  Thanks for posting this.
Nov 5, 2009. 9:12 AMzygomatic says:
Very nice work!  What kind of fogger do you have and what kind of fog juice do you use?
Nov 5, 2009. 5:36 AMchrispaccord says:
 Did you add any kind of spacer between the pvc and the nozzle for the fog machine?  I've tried using pvc to route the fog from a machine before, but was uncomfortable with the heat of the nozzle and the proximity of the pvc...
Nov 4, 2009. 9:44 PMotoupalik says:
 That is so cool! Great work!
Nov 4, 2009. 7:15 AMDSalyer says:
I was thinking of doing the same thing myself but did not know how the straight cannon barrel would look.  It looks fantastic!
As for the light and sound being synchronized with the fog machine, I think a simple solution might be to add a motion detector in the barrel. I think it might detect the fog and then could set off the light and sound feature.  Let me know if you try it and it works.
Oct 31, 2009. 6:06 PMjamesjmg30 says:
How long did it take you to make that on Solid Works? we use it a school and we never get to use all of the features like the rendering we just design and print the design sheet
Oct 31, 2009. 10:32 AMMACKattacksnipe says:
Very nice
Oct 31, 2009. 9:15 AMBartboy says:
Gives me an idea:
Cannon stereo!
The cannons could be speakers, and "shoot" sound!
Oct 31, 2009. 8:39 AM~Sasquatch~ says:
What a 1st Class Idea, and Instructable! KUDOS!!
Oct 31, 2009. 7:36 AMlittlegandhi1199 says:
 That's a very good idea
like you said a bright red light flashing off would be good and maybe have that light go off and then the fog come out within split seconds.
And another addition to make this seam like it is being shot off you could mount speakers inside the design and have a recording of a loud explosion go off
I think that would be very cool!
Oct 31, 2009. 4:04 AMTool Using Animal says:
Wowzer!  great project
Oct 30, 2009. 9:56 PMfungus amungus says:
Great stuff! Really nice finished look and I dig the Solidworks planning.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:markeike
