3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halloween Project "Cobweb"
Halloween Project \"Cobweb\"
Step 1Draft
Draft
Draw cobweb
13 comments
Oct 3, 2010. 3:41 PMglassylady says:
Great idea. What background material did you draw and hot glue on to ? Why did it not stick to the back ground and peel off with out breaking? Did you use Pam?
Sep 3, 2008. 5:48 PMbassclarinet23 says:
Do I let it dry completely?
Oct 31, 2008. 5:09 PMResourceful says:
Cold and hard It's a clear hot glue!
Oct 11, 2008. 3:45 PMsanty22 says:
cool
Oct 10, 2008. 8:20 PMalex-sharetskiy says:
Aww, no talking in the video?
Sep 16, 2008. 1:20 PMMonsta says:
Actually, I think you could get a huge plastic tablecloth and just hot glue a starburst shape on it, (the basic crossed lines of a web) and allow them to dry/harden. Start with one vertical, then one horizontal and so on and you won't even have to draw the design first. After the glue is dried, just start in the middle and hot-glue the ever-widening spiral. (I imagine having the lines dry would make it easier to crawl over it while you do the rest, so it doesn't stick to YOU!) I doubt the hot glue would stick permanently to a plastic tablecloth, and, after testing a small spot if you find it does, you could spray cooking spray on it first. No need to draw the entire web (what a chore!) that way. Plus, you could make it as large as your tablecloth (Dollar store!) As an afterthought, what if you used the heavy duty plastic tablecloth with the white fuzzy fabric on the back and used that side? Then you'd want the glue to stick and when you peeled off the finished web, it would have white fuzz on it. That might be cool too. Just thinking out loud...
Oct 23, 2007. 1:16 PMgamer says:
that must have taken so long to do. very nice.
Oct 21, 2007. 6:26 PMhavanacus says:
What is that your putting the hot glue on? It looks like marble but I can't imagine somebody drawing on a marble counter with marker and then hot glue... It would probably be easier to remove then any other surface I guess...
Oct 22, 2007. 9:41 AMSpectrace says:
i believe its plywood, because hes doing it on the floor.
Oct 22, 2007. 12:21 AMadamazing says:
Dangitall...now I look at that again...I see what you mean! I'd just assumed that it was on greaseproof paper or something similar, without really looking too hard at it...
Oct 21, 2007. 4:53 PMSpectrace says:
thats cool, i think hot glue glows in a blacklite, like light purple i think, thats cool, you should try that.
Oct 21, 2007. 4:24 PMJohn Smith says:
Would it help of you sanded the plywood before you glued it? Maybe then if it stuck after that, you could use candle wax to lube it for an easier release.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:msolek
