Halloween Slime
476
Published
Introduction: Halloween Slime
This is a tutorial on how to make Frankenstein Slime!
Step 1: To Make Your Slime You Will Need:
-Something to mix with
-1 cup measurement
-1/4 cup measurement
-1 table spoon measurement
-2 bowls
-Glue- HAS TO BE ELMER'S!
-Borax
-Food dye- I chose green for this themed slime but any color will work.
-A mix in- I chose googly eyes for this themed slime as well.
Step 2: The Base of the Slime
In one of the bowls, mix about 1/4 cup of glue and 1/4 cup of water together. Once it looks kind of cloudy and is mixed in together, add in your mix-ins. Everything should be kind of slimey/gooepy and mixed in with each other.
Step 3: Part 2 of the Base
Mix 1 cup of water and 1 tablespoon of borax together in the bowl. Mix until most of the particles of borax are mixed into the water. Then, add 8-10 drops of food coloring in. You can add more or less depending on how dark you want the color. Make sure all of your food dye is mixed in and there is no streak of color in your mixture.
Step 4: Mixing It All Together
For the last part, you want to combine bowl 2's mixture with bowl one. So very slowly, about 1 tablespoon at a time, add in the green mixture into the white mixture. It is VERY important you do this slowly because too much liquid in the slime could ruin it by making it very watery. Your slime should be very clumpy and when you press it, it should be kind of sticky (it should feel like goope/slime). Once there's no more streaks of color and everything look very well mixed it should be ready to use!
Step 5: ENJOY!!
Hope you enjoyed making your slime! Have fun!
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    That is cool is there any other way to make it?
