Halls Sensor Using the Linkit One
325
6
Posted in TechnologyElectronics
Introduction: Halls Sensor Using the Linkit One
In this instructable I'm going to show you how to work with a Halls sensor using the Linkit One. The halls sensor is a sensor that detects magnetic fields.
Step 1: List of Parts
  • Linkit One
  • Halls Sensor from Seeed Studio
  • Micro USB Cable
Step 2: Halls Sensor
Connect the signal pin from the halls sensor to the linkit one D7 pin, and connect the vcc to the +5v pin and gnd pin to gnd.
Step 3: Micro USB
Next you need to connect a micro USB between the Linkit One and your PC, and install the necessary drivers from the Linkit One official site.
Step 4: Code
Use the arduino IDE to upload the code to the board, you need to modify the IDE to make it support the Linkit One board.
<p>#define HALL_SENSOR 7<br>#define LED	14//the Grove - LED is connected to D4 of Arduino
void setup()
 	pinsInit();
void loop()
	if(isNearMagnet())//if the hall sensor is near the magnet?
		turnOnLED();
	else
		turnOffLED();
void pinsInit()
	pinMode(HALL_SENSOR, INPUT);
	pinMode(LED,OUTPUT);
/*If the hall sensor is near the magnet whose south pole is facing up, */
/*it will return ture, otherwise it will return false.				*/
boolean isNearMagnet()
	int sensorValue = digitalRead(HALL_SENSOR);
	if(sensorValue == LOW)//if the sensor value is LOW?
		return true;//yes,return ture
	else
		return false;//no,return false
void turnOnLED()
	digitalWrite(LED,HIGH);
void turnOffLED()
	digitalWrite(LED,LOW);
}</p>
Step 5: Run Time
Bring a magnet near the sensor and you should see the on board LED at D13 Light up.
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
