Simply use a burnt out projector and a Work Light from Home Depot and bring the theater home!
The OEM replacement bulb for my projector cost $300 (!) , more than what I paid for the projector it self. Also, my power supply that powered the original bulb was almost toast. Using this guide, you can use a Halogen Work Light bulb for about $10 dollars.
If you like this mod please Digg It!
This project is a redo of my Automotive Head Light Projector Mod
WARNING: This mod involves modification of a projector, electrical wires, switches and a high power bulb. If you are not comfortable with modding on this level, DO NOT attempt this mod. The writer is not responsible for any injuries or damages resulting from these instructions.
Remove these ads by
Signing UpStep 1Obtaining the Work Light
In their Electrical Section you will find a small ~$10 250 Watt Halogen Work Light
Make sure that the bulb is 3.15 inches NOT a 4.69 inch or it may not fit.
You will want to measure the space that you have in your projector before going to the store.
You can get 3.15 inch bulbs that go from 75 to 400 watts in 3.15 inch. However, remember that even though more watts means more lumens, it also means more heat.
(We don't want to melt the projector or start a fire)
Once you have found the bulb that will fit your projector, Buy it and continue to step 2. ------->
I am using an acer pd100 projector, but it does not power up unless there is a working bulb in it, now I have to trick it into thinking that there is a bulb in by using a resistor but i have no clue wich one to use.
I have looked up the bulb but cant seem to find how much power it uses, that is if its 12 volt or 220 (I am in europe)
the bulb:
http://www.oztion.com.au/buy/auction.aspx?itemid=9673891
any ideas as to what strength resistor I should use?
I first removed the HV flyback trafo, and tried that way on my new benq :)
It did not work, and i had the same problem as you do, then I looked at the circuit and saw that there was only the power wires and the sensor wires(the lamp HV pcb is seperate from the rest. the sensor circuit wires had only 1,2 v dc, so i tried to conect them directly guessing that the lamp circuit works as a switch and it works . now i just need to put a stronger bulb in,this one is only 60w and maybe it wil pass in complete darknes. cheers
depending on how many lumens the projector is, I will find one that matches that. Please tell me if you think this will work and feel free to add any suggestions.
Im verry impressed that you have taken on the project keep going your almost there!
-VIPER!
- Is your halogen projector mod still going?
- did you modify the fan in the MVP800 to work on all the time or did you just leave as is?
- did you disconnect the original wires for the light of the projector or did you just take the mounting off?
- does it produce excess heat? how did you manage to solve this problem?
thanks!
And I'm working on a website dedicated to my projects and the projector mod that stirred up so much excitement. Check back here for a link when the site is ready for public consumption. I will be adding lots of my projects to the site as well as a new detailed look at the projector mod.
Yes the old girl is still going! We have watched many movies on the weekends with it.
The fan always runs when the projector is in standby and should run twice as fast when it is turned on. So you should turn the bulb on after the projector fan is moving. The fan already runs at a good speed and the bulb is about as hot as the original bulb so no modification was necessary. I removed the original wires and the mounting from the projector as the igniter wasn't working.
For people wanting EXACT step by step instructions. This is a prof of concept and explanation of how I did the mod on MY projector every projector is going to be different unless you can get a hold of the same or a similar model. Many of my ideas for other projects come from a brief explanation of how something works or a picture of a similar project. It is up to you to look and think about your idea and solve the problems to make it function. I built the projector mods in about 5 or 6 hours and had to think up almost everything on my own.
If you put you mind to it you can accomplish anything. -Dr. Emit Brown
Too bad really. There are some good french websites on modding your projector:http://www.allinbox.com/modding.htm
unfortunately they are in french.
I have a 3M mp8755 that I would like to mod this way. Unfortunately it isn't possible from these instructions.
Congrats on getting this to work.
It feels like this mod is 90% complete, and leaves the experimenter hanging with a few steps to complete.
ANY info would be great. Even successful mods on any other retail projectors. Inquiring minds want to know!
