3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halogen Work Light Projector Mod V2.0
A Home Theater that won't brake the bank.
Simply use a burnt out projector and a Work Light from Home Depot and bring the theater home!
The OEM replacement bulb for my projector cost $300 (!) , more than what I paid for the projector it self. Also, my power supply that powered the original bulb was almost toast. Using this guide, you can use a Halogen Work Light bulb for about $10 dollars.
If you like this mod please Digg It!
This project is a redo of my Automotive Head Light Projector Mod
WARNING: This mod involves modification of a projector, electrical wires, switches and a high power bulb. If you are not comfortable with modding on this level, DO NOT attempt this mod. The writer is not responsible for any injuries or damages resulting from these instructions.
Step 1Obtaining the Work Light
'Step 1: Go to HOME DEPOT'
In their Electrical Section you will find a small ~$10 250 Watt Halogen Work Light
Make sure that the bulb is 3.15 inches NOT a 4.69 inch or it may not fit.
You will want to measure the space that you have in your projector before going to the store.
You can get 3.15 inch bulbs that go from 75 to 400 watts in 3.15 inch. However, remember that even though more watts means more lumens, it also means more heat.
(We don't want to melt the projector or start a fire)
Once you have found the bulb that will fit your projector, Buy it and continue to step 2. ------->
57 comments
1-40 of 57next »
Jan 12, 2010. 10:51 PMtatay66 says:
Not to hard to figure out all he did was to replace the standard bulb with a halogen lamp, thats already wired, then he drills a hole in the side of the projector casing instead of trying to wire it up direct to the projector power supply. Then he actually has two seperate switches one for the light and one for the projector. The thing to note is the fact that he cautioned the need to have extra cooling such as a larger fan. Its really all simple reverse engineering and running the existing wires from the halogen light to the original wire as in piggy backed lol. As far as the projector cooling time it should still be automatic he didnt change the circuit all he did was add a stronger light. To be positive on this the bulb doesnt cost an arm and a leg to get and all the wire and circuit you need are already there. BE NICE he did explain you would need to find one that will fit your projector.
Jan 14, 2012. 12:28 AMflyingpumpkin says:
most projectors have an auto-shutoff if there is no current running through the bulb. This would have to be bypassed to make it work somehow. There is more to it than just powering the projector and bulb separately. As nearly every other post here points out....
Apr 12, 2010. 8:40 AMsiggibahama says:
hi,  I am geared up and ready to do this instructable, I am quite exited and cant wait to pop some corn and have a movie night,  I am having a problem though that maybe you can help me with.
I am using an acer pd100 projector, but it does not power up unless there is a working bulb in it, now I have to trick it into thinking that there is a bulb in by using a resistor but i have no clue wich one to use.
I have looked up the bulb  but cant seem to find how much power it uses,  that is if its 12 volt or 220 (I am in europe)
the bulb:
http://www.oztion.com.au/buy/auction.aspx?itemid=9673891
any ideas as to what strength resistor I should use?
May 21, 2011. 9:52 AMTkdwn says:
try, tricking it in the sensor circuit, not the actual power circuit for the lamp.
I first removed the HV flyback trafo, and tried that way on my new benq :)
It did not work, and i had the same problem as you do, then I looked at the circuit and saw that there was only the power wires and the sensor wires(the lamp HV pcb is seperate from the rest. the sensor circuit wires had only 1,2 v dc, so i tried to conect them directly guessing that the lamp circuit works as a switch and it works . now i just need to put a stronger bulb in,this one is only 60w and maybe it wil pass in complete darknes. cheers
May 21, 2011. 12:38 PMTkdwn says:
This is it at 2x60W , NEED MOOAR!!1!11
Apr 2, 2011. 8:44 AMmatthewkhoury75 says:
Hello, I was thinking about doing a project like this. I wanted to know if you have ever tried to use a high power LED instead of a halogen light? If I were to attempt this I would most likely use one that is colored bright white: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320590927002&ssPageName=STRK:MEWAX:IT
depending on how many lumens the projector is, I will find one that matches that. Please tell me if you think this will work and feel free to add any suggestions.
Jun 30, 2010. 12:14 PMkingbowser says:
Hi, later this summer I'm planning to mod a LCD projector which has no lamp. I come across this producer: http://www.hueyjann.com.tw/self_pages/en/application.html It offers high power LEDs (up to 100W), with an high CRI of 90. I'm now asking them where I can find a sample of their HPR40E-19K100NWG/CRI 90. The PSUs are easy to find on the eBay (search "100W led ac driver"). As a collimator I plan to use some short focal length fresnel lenses, which you can find for example here http://www.knightoptical.co.uk/acatalog/LensesFresnellensesStandardrange.htm If you couple two or more lenses you'll have an equivalent focal length f/n, where n is the number of lenses you used. So you can have a rather thin, but powerful, lens. Maybe you'll need a tempered glass as those lenses are made of plastics, and too much heat would melt them. The biggest problem is the heat: you have to dissipate a large amount of power, so it will be impossible to fit this setup in a lamp housing, you will need at least a heatsink coming out of the projector, maybe also a fan and/or a peltier cell. But you'll have a great light source: a LED with 90 CRI and 5800lumens. What do you think? [it would be a little pricey though...]
Mar 3, 2010. 3:59 AMpervy_sage says:
Viper help! I am at this stage now. but the ceramic holders of my halogen lamp are hitting the cone mirror on the heat shield. Let me guess your ceramic holders just happen to be low profile and you never had this problem.
Jan 21, 2010. 12:31 AMmonkeey says:
i have an optoma ezpro 585 and it seems to be the exact same projector as yours in every way except name . my bulb has maybe another 30 hours on it and i am gearing up to try this mod, i just had a quick question, how did you mount the bulb in the old bulb's place. i am guessing a few squirts from a hot glue gun wont work lol....
Mar 2, 2010. 10:07 AMmonkeey says:
i will try the thin wire if all else fails, i was thinking of using some jb weld to 'weld' the lamp holder in place. i used it on my car engine and its held pretty well and it gets really hot so im sure it would work here. Also i found the same light you got but mine came with a foot long power cable and no switch. i was able find a switch that will work and im adding a longer cord but the thing that worries me is there is a thin piece of glass in front of the bulb that has " uv filter - do not remove" on it. DId yours have this and if so have you had any problems running the projector with out it? i really dont want to get a tan while watching a movie ....
Jul 30, 2009. 2:25 AMhantly says:
hi there i am stuck at this stage. i really want to do this project but i am just stuck at this one stage. you see i have an acer PD113. please can you search this projector and tell me where i will have to drill these holes. the bulb is at the bottom but i cant seem to remove the shell. thank you hantly
Mar 1, 2010. 9:19 PMpervy_sage says:
Hello Viper it has been two years since you made this mod. I don;t know if you are still there or even reading this. But would like to know the following.
- Is your halogen projector mod still going?
- did you modify the fan in the MVP800 to work on all the time or did you just leave as is?
- did you disconnect the original wires for the light of the projector or did you just take the mounting off?
- does it produce excess heat? how did you manage to solve this problem?
thanks!
Feb 5, 2010. 6:24 PMTomcat94 says:
Now, if there was a mod for the EyeClops mini projector to make it project REALLY well, that would be AMAZING. :) Make it happen, instructables!
Jan 3, 2010. 8:41 PMflyingpumpkin says:
Nice idea, but this instructable is no where detailed enough for me to repeat.  There are more pictures of the switch you put in then exactly how you bypassed the projector's auto-shutoff function.  I  can tell what you've done there. It would be nice to have something step-by-step before, pointing to the wires you are targeting, showing one-by-one which you have modified.  You've only photographed it after completed and not how you did it.  An instructable should, well be instructions that will allow it to be repeated by users rather than just some pictures of your neat setup.  Perhaps more of the photos of the Mod and less of the popcorn maker...
Too bad really.  There are some good french websites on modding your projector:http://www.allinbox.com/modding.htm
unfortunately they are in french.
I have a 3M mp8755 that I would like to mod this way.  Unfortunately it isn't possible from these instructions.
Congrats on getting this to work.
Nov 9, 2009. 1:20 PMCorndog1337 says:
Hey guys I got the lightware vp800 model and didnt know if anyone knew about retrofitting with an small lcd monitor to give it better resoultion. Anyone got a tutorial or know how to start this project?
Jul 29, 2009. 10:28 AMhantly says:
hi i live in the uk i was just wondering do you think anything very similar will do the same job. but i really like the idea and i am going to try it just need to know tht question thank you hantly
Jun 19, 2009. 9:12 AMMillenniumMan says:
Had to replace the entire balast in my old projector (chinese made of course) I used a similar method, but not a halogen worklight. Suffice it to say, I'm going to (re)mod my older work and use this method since the replacement 150 watt incandescent bulb and flexible auto mirror method I used probably isn't as bright as this (1600 lumens) But it'll mean a faster and longer running cooling fan.
Jul 1, 2008. 10:33 AMxeniczone says:
This is probably a bad idea. I would stick with the Car Headlight bulbs. Those Halogen bulbs are in that yellow case for a reason. The glass on the front of that is made to block out harmful rays that come from the Halogen Bulb. More specifically. The UV rays from the light. These are extremely harmful rays. That can give you sunburn, which can accelerate skin cancer. Like I said this isn't a good idea.
May 6, 2009. 12:37 PMpcfixit says:
Hate to burst your bubble xeniczone, there is an absolutely misicule risk of skin damage because of these halogen lamps. Although it is true that exposure to UV light can accelerate skin cancer and cause damage, due to the tiny amount of UV light emitted by these, only very prolonged exposure to them can cause skin damage. And to add to this most commonly avaliable halogen bulbs, such as the linear sort used in work lights etc, have a UV filter coating on the lamp itself. I know this will seem like I'm having a bit of a pop at you, but its more to clear up any misconceptions people might have about this. Great Instructable by the way VIPER2475, keep up the good work.
Feb 7, 2010. 4:39 PMxeniczone says:
 Not really the skin you should worry about.  Its your eyes.
May 5, 2009. 1:37 PMmacrumpton says:
Are you sure about that? These bulbs look just like the ones that are in the cheap torchiere type lamps that you can get at any department store, and those don't have any warnings or elaborate UV shielding.
Sep 23, 2008. 1:55 PMbtop says:
So this projector will now give people who watch a film on it cancer? I wouldn't be surprised, everything seems to cause cancer nowadays...
Sep 25, 2008. 11:46 AMxeniczone says:
not specifically cancer, more like sun burn, or can hurt your eyes because of the amount of IR coming from it. it would be possible to put an ir filter inside the projector...
Mar 16, 2009. 7:52 PMTheBestJohn says:
Just buy a UV lens filter for digital cameras for 15 smackers at any photography store... that should work
Sep 27, 2008. 2:10 AMbtop says:
This instructable should be renamed "Mod your projector into a tanning booth"
Apr 8, 2009. 10:47 PMBobS says:
I have heard (but not tried) that water with a little (only slightly bluish) copper sulfate dissolved in it blocks IR. That would make a great coolant to put in between glass plates just before of the LCD screen. It would accumulate the heat, so it should be pumped into a mini radiator, perhaps a part from a fridge radiator??
Feb 28, 2009. 4:51 AMericlorda says:
I already did this work at the overhead projector .It works and save money just a few modification on the wiring and the mounting of the bulb.
Feb 3, 2009. 9:11 PMcat3rn says:
I do like this mod very much but I have just a couple of questions. Why have 2 power cords coming out? Why not just wire the original power cord that powers the projector to also power the light that way when you shut the projector off the fans keep going for a few minutes to cool down the lamp?
Jan 23, 2009. 9:09 PMbad_german says:
so it heats up... perfect for making popcorn eh? just attach a pot over the bulb, add butter and corn and wait...
Dec 16, 2008. 7:43 PMlowflyingdutchman says:
Noobie here with a question. Despite the cancer causing effects of this mod ;) I would like to try it. I have an old 3M projector and after the bulb busted and I found the replacement bulb would set me back some 200, this is one elegant solution. So after opening it up, I found the leftovers of what suspiciously looks like a halogen worklightbulb in the first place!. not to mention the fact that it has apparently been chewing up 400 watts! Now for my question.. Is it reasonable to assume that since the original bulb (that is rated for 400 watt) can be replaced with a halogen bulb of the same wattage? would it generate pretty much the same amount of heat? I can see where the swap would be childishly simple because, like I said, the bulbseat pretty much already looks like what one would find in a worklight. Would appreciate any reply!
Aug 29, 2008. 8:06 AMSynaptyc says:
Can anyone who has had success (or not) with this please add their results to this post. I really want to try this, but I would like to know if it actually works well, or if it is better to stick with OEM parts. Screen shots would help so many people with this project. You know... fan attachments, running shots, side-by-side shots of the OEM light bulb and the modded light source.
It feels like this mod is 90% complete, and leaves the experimenter hanging with a few steps to complete.
ANY info would be great. Even successful mods on any other retail projectors. Inquiring minds want to know!
Sep 14, 2008. 5:46 PMxeniczone says:
A picture would be useless because a picture quality will only reflect the quality of the camera. It would not show a true brightness or a true color contrast.
Jul 30, 2008. 2:23 PMeduardo1979 says:
How long does the light (250 watt halogen) will last? because proyector lights last more less 3000-4000 hours great article
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:VIPER2475
