Step 7It's SHOWTIME!
Invite your friends over to the movies and show them the projector you modded.
Pop popcorn and through in one of your favorite movies.
Please check out my other projects:
Automotive Head Light Projector Mod
Upgrade from VISTA to XP
CAUTION : This Halogen bulb is MUCH HOTTER that the automotive headlight that was used last time.
You will need a significant amount of air flow through the bulb chamber to cool the bulb and NOT START A FIRE! Also, keep the bulbs power cord unplugged, you don't want someone turning on the bulb with out the fan. I am not held responsible for damages due to improper use of your projector.
My next project how to make perfect popcorn!
This popcorn popper makes great popcorn. Legend has it it was discovered abandoned in a work camp on the Alaskan pipeline.
I am using an acer pd100 projector, but it does not power up unless there is a working bulb in it, now I have to trick it into thinking that there is a bulb in by using a resistor but i have no clue wich one to use.
I have looked up the bulb but cant seem to find how much power it uses, that is if its 12 volt or 220 (I am in europe)
the bulb:
http://www.oztion.com.au/buy/auction.aspx?itemid=9673891
any ideas as to what strength resistor I should use?
I first removed the HV flyback trafo, and tried that way on my new benq :)
It did not work, and i had the same problem as you do, then I looked at the circuit and saw that there was only the power wires and the sensor wires(the lamp HV pcb is seperate from the rest. the sensor circuit wires had only 1,2 v dc, so i tried to conect them directly guessing that the lamp circuit works as a switch and it works . now i just need to put a stronger bulb in,this one is only 60w and maybe it wil pass in complete darknes. cheers
Too bad really. There are some good french websites on modding your projector:http://www.allinbox.com/modding.htm
unfortunately they are in french.
I have a 3M mp8755 that I would like to mod this way. Unfortunately it isn't possible from these instructions.
Congrats on getting this to work.
