3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Halogen to Fluorescent Torchiere Lamp Conversion
This project got started because I was going through $2-$3 300 watt halogen light bulbs about once a month and because the lamp in my office made as good a heater as it did a lamp.
I wound up converting 3 lamps for a total cost of about $12 in lamp parts
6 ceramic light sockets
2 3-way switches
1 25' roll of 14awg single conductor stranded copper wire
The lamps have been working great for about 3 months now. They're saving me money on electricity and light bulbs.
Step 1Evaluate your lamps and decide what you need
I had 3 lamps I wanted to convert (one was already fluorescent but with a blown ballast) the 2 halogen lamps had dimmer switches which won't work with fluorescent lights and if left on low will burn them out pretty quick.
I found a three way chain switch at the hardware store which looked like it would fit in the tube in place of the dimmer switch.
The pre-fluorescent lamp already had a 3-way rotary switch so there was no need to replace it.
31 comments
Apr 15, 2011. 1:57 AMsupreme-ette says:
Could a 300 watts burn an acetate sheet? We're gonna use the 300 watts as the light source for an improvised projector, and since we've got no lcd to have images be delivered then projected, so we opted for acetate sheets.
Dec 4, 2009. 8:27 PMkmossman says:
(removed by author or community request)
Nov 27, 2009. 9:04 PMdiy_chad says:
Make sure you are switching the hot and not the neutral.  You do not want to have a hot wire at the sockets when the switch is off.
Jun 15, 2009. 11:40 AMnaruto the ninja13 says:
pardon my ignorance but what is a halogen bulb?
Jun 3, 2009. 9:16 PMacer359 says:
Can you do this LEDs?
Jun 5, 2009. 6:43 PMacer359 says:
do you still have the dimming effect?
Dec 25, 2008. 10:07 PMxrayangiodoc says:
If I'm reading the circuit diagram properly it looks as if either one or the other CFL would be on at a time. Wouldn't it be more flexible to have a switch that would allow one, or the other, or both CFLs to be on at a time? That way you could have a 15 and 23 watt CFL and get 3 different levels of light output. Nice project. I hate the halogen torch lamps in my home and almost never use them. They are just about the only incandescent lamps left in my home.
Oct 25, 2008. 3:18 PMBigAl323 says:
A++ you just saved one lamp from going into the garbage. I was keeping it even though it didn't work anymore. it now has 2 mini CFLs in it. wished it would give out more light but might just be the fact i bought mini's. A++ on Instructable. Alex
Jun 21, 2008. 4:13 AMAction Pat says:
Those halogen bulbs are one hell of a fire hazard around drunkies. Sweet instructable
Jun 20, 2008. 12:01 AMjbgruver says:
Usually when you speak of wire size it is the amperage that is important. 110-120 VAC 60 HZ is usually understood to be the voltage. You can take the "Wattage" of the lamps and divide by 115 and get the amps Fluorescent bulbs use very little wattage so number 14 or 16 gauge multi strand is more than sufficient. Thats my 2 cents worth.
Jun 6, 2007. 1:18 AMn0ukf says:
those halogen bulbs (any incandescent for that matter) last longer if you don't run them at full brightness. The two torchier floor lamps I have are dimmer models which I normally run at a lower than full level. I haven't had to replace a bulb yet (now the halogen work light is a different matter as it has no dimmer). But then again the fluorescents are good for energy savings, I'm changing to those wherever i don't have a dimmer.
Jan 3, 2008. 1:12 PMBig Bwana says:
Halogens don't last longer if dimmed, dimmning them actually reduces there life by a huge percent and causes the tube to go black, because you interupt the halogen cycle which requires a certain tube tempurature for it to work... (( If you want them to last there full life time consider getting the right voltage tubes not the standard 130 volt home depot specials )) But YES CFL's or even GE double D shaped flouresent tubes are the way to go... plus it costs less in airconditioning your office space to...
Mar 3, 2008. 12:05 PMn0ukf says:
I just replaced my 300W bulb a couple months ago but not because it burned out (it didn't, and I'm not even seeing any signs that the dimming had any adverse affects on it). I actually found a 150W bulb in this same larger form (there's smaller ones of the same tubular style, only up to 150W), so I can run the dimmer higher for the same (and whiter) light as I was dimming down to with the 300W bulb. As i said before, for other non-dimming fixtures, I'm switching to fluorescents. Though they're not so good outside and in the unheated garage where they don't start so well in sub-zero (F) temperatures.
Feb 20, 2008. 5:07 AMsobemanhoss says:
can you just do a conversion to a single CFL or does it have to be two?
Feb 20, 2008. 8:58 AMsobemanhoss says:
thanks! this is awsome!
Feb 13, 2008. 8:30 PMwingman358 says:
I just did a halogen to CFL conversion with my torchiere. I replaced the halogen with two 60w CFL's. I used this instructable and another similar instructable. Took me about 15 easy minutes. Thanks for the idea and great instructable!
Sep 11, 2006. 5:47 PMgrg3 says:
Thanks for the inspiration. I was able to fit three bulbs and enable them to light 1,2,3. It works great!
Mar 17, 2007. 7:11 PMgingero says:
How did you get them to light 1, 2, 3? I'd like to do that.
Jan 28, 2007. 3:48 PMlemonie says:
I'm probably going to be the only one to say "fluorescent"
Sep 12, 2006. 8:05 PMMz3FRS says:
Nice write-up! One minor point, when it comes to voltage, wire gauge does not matter, the insulation does. A 20AWG wire and a 1AWG wire with the same insulation will carry the same voltage. The key for conductor gauge is current. 1AWG wire is good for upwards of 100 amps, while 20AWG is only good for about 5-10. Not sure about the wattage of you bulbs, but 14AWG should be a good, conservative size. How bright are they in comparison to the original Halogen? Again, good work.
Mar 31, 2006. 6:33 PMdan says:
looks like you could probably fit 4 lights in there!
Mar 31, 2006. 6:31 PMinstructables-dan says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wperry1
