Hammered Wire Necklace
 by susanrm
Featured
Step 4: Assemble the neck wire
Gently bend the 12" wire into a circle that will fit comfortably around your (or the wearer's) neck. It does not have to reach the whole way around.
Bend under the two ends of the neck wire to form loops.
Then attach each of the links. Put two on one side, and one and the clasp on the other. Close up each of the links.
Test your clasp to make sure it fits through the links. If not, adjust as needed. You can also add or remove links as needed to lengthen or shorten the necklace.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
