The clasp can be made in petite sizes or large, bold sizes depending on the wire gauge used. Smaller clasps can be made on 1 mm (18 gauge) round wire and larger clasps made on 1.5 mm (14 gauge) round wire. I would not suggest using any smaller than 1 mm (18 gauge) round wire as the wire becomes too thin to remain sturdy.
The wire used for this clasp is continuous wire, a commodity usually kept by wire artists. The clasp is easily created once the technique is learned, readily available in the workshop and low cost compared to commercially purchased bold clasps.
The clasp works equally well in brass, copper, silver and gold wire. The clasp allows construction straight from the wire spool to minimize metal waste.
I recommend practicing the clasp in copper or brass for the first time before using silver or gold.
This is a perfect first wire project to learn a few new techniques such as:
Work hardening
Hammered Texture
Basic Loop creation
Spiral creation
Flattening wire
Filing
Sanding
Remove these ads by
Signing UpStep 1
Round Nose Pliers
Wire Cutters
Ball Peen Hammer
Metal File
280 and 400 grit sandpaper
Steele plate (or other suitable surface, see step 8 notes)
Materials required:
10 cm of 1 mm (18 gauge) to 1.5 mm (14 gauge) round wire in Copper, Brass, Silver or Gold
I use these clasps on the wire bracelets I make like this one:
http://www.web4business.com.au/amandasjewellery/images/bracelet_wrap_brass_green.jpg
but I don't see why not!
Smashing if also effective and fast when one want reinforce a wire hook.
