3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hammock Stand - Indoor & Outdoor
After a summer of taking my little portec hammock on canoeing and camping trips, I decided that I wanted to be able to enjoy the hammock in the winter too! Our winters get to -35c and it's not so comfortable outside anymore!
I'm always interested to hear constructive criticism!
Step 1Materials
Materials
Materials
 4 - 4"x4"x10" posts
12 - lag bolts (I think I had 3.5") & washers
  8 - 2" eye bolts w/ wood thread
  3 - 3" eye bolts w/ wood thread
  4 - turnbuckles
  ? - aircraft cable (I used high-tensile climbing rope, which has some acceptable give to it.)
Tools
 - compound mitre saw (what I used) / chop saw / hand saw
 - sockets to fit the lag bolt you choose
 - drill and/or socket wrench
 - 1" spade bit
 - a spade bit - slightly larger than the diameter of your lag bolt
 - a wood drill bit - slightly smaller than the diameter of the threads on your lag bolts
 - measuring tape
 - sharp knife
 - small leverage bar to aid in threading eye-bolts into wood
9 comments
May 1, 2012. 12:51 PMbuenoben says:
I built a stand based of this Instructable, this is how it turned out.
I used treated 4x4 (only thing available at the Home Depot I was at), something I later regretted when I was going to stain it as I was told the stain wouldn't stick. I guess the wood was dry enough because after sanding it down with a hand sander the stain was absorbed by the wood just fine.
Thanks for the guide forke!
Jul 22, 2011. 1:00 AMmikesnyd says:
I2 order for you to achieve the angle you wanted on your miter saw you just need to add a wedge to your miter saw fence. Then you will need to have a saw horse or something to hold up your stock due to it not running straight across your fence anymore.
So you were after 28 degrees. All miter saws are currently set to 90 degrees.
By adding a wedge along your rail you adjust the original 90 degree set to 45. Now just swing your arm over 17 degrees and voila. Also i must say the tip of the wedge has to just meet the blade. If you make the wedge kinda wide you can drill a large hole in it and quickly clamp and unclamp it to you fence with a screw clamp or quick grips. Alliteratively you can just add a piece of wood to your wedge that acts as a wall and just clamp that you your miter fence.
I usually make the wedge longer so i have more straight side as a rail for accuracy sake sorry my quick mspaint drawings are not to scale.
Nov 7, 2011. 2:57 PMparacordlover says:
nice job!, thanks for this reply, im about to make this and this helped alot. nice work
Jul 12, 2011. 1:56 AMmatcullen says:
how about weight supported ?
Jan 6, 2011. 5:15 PMjdubbery says:
Thank you for introducing me to Google Sketch. It makes me so happy. Also your hammock stand is awesome, and I will be replicating it shortly.
Dec 31, 2010. 12:56 PMerazor983 says:
I would be careful with your new "coasters" from the cutoffs, especially if you have small children or pets around. There is virtually no food safe compound currently being used to pressure treat lumber.
Dec 31, 2010. 12:18 PMrimar2000 says:
Great idea!
Dec 30, 2010. 9:19 PMdchall8 says:
Climbing rope is great for lateral stiffening. Polyester (Dacron) would also work. What will not work is nylon rope. Nylon stretches forever.
Another approach to stiffening it laterally would be to use a 1/4-inch plywood web.  Use Gorilla Glue to really keep it tight.
Did you mean to put some dimensions in this Instructable?  I believe for most hammocks the connecting ends must be 14 feet apart.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:forke
