loading
Here's a small bowl I made from interlocking layers of birch plywood. I designed it using Poser, Blender and Autodesk 123D Make, then used a laser cutter to precisely cut all 40 of the pieces.
The bowl stands at about a foot in height and, despite being very light, is sturdy and extremely well balanced so it won't topple over when filled.
You can now buy a kit for this bowl on the Instructables Store. We're making these ourselves at the Instructables Lab, so supply will be limited!
Step 1: Modeling the Hand
The first step was to model and pose a hand to act as the bowl's base. For this, I used a piece of software called Poser by Smith Micro. Poser is a 3D modeling package that specializes in modeling and animating human bodies. It comes with a library of basic figures that can be easily posed using a very intuitive and beginner-friendly interface. I used one of Poser's default hand models.
When posing the hand, I had a few things to bear in mind. Obviously I wanted all of the fingertips to touch the ground at the same level so that the bowl would stand upright. I also had to think carefully about the way I splayed out the fingers. The fingers needed to provide as broad a base as possible while also looking natural and comfortable (Poser does nothing to stop you contorting its models into grotesque and unnatural positions, so this is trickier than you might expect).
A more subtle issue was to do with how I knew the model would eventually be sliced when I exported it into 123D Make. I knew from the outset that I wanted this bowl to made of radial slices converging somewhere around the base of the palm. This meant that I had to position the fingers so that they all roughly pointed straight outward from the same spot (so that each finger would contain a slice of plywood). Any major misalignment would make slicing the model impossible. This is an excellent example of how crucial it can be to visualize the entire design process of a project before you even start modeling.
Step 2: Adding the Bowl
I exported the hand from Poser as an OBJ file, then imported it into Blender, a free and open source 3D modeling program. In Blender, I modeled a simple bowl by using basic Boolean operations between three spheres.
I positioned the bowl above the hand and connected the two by extruding a segmented stalk from the wrist, which I then manually posed before using the "Smooth Vertex" to achieve a smooth, flowing path between the parts.
I also used Blender to make sure that all of the fingertips were level, by slicing them all off with along the same plane. Nothing's more annoying than wobbly furniture.
Note again that I had to carefully consider how I planned to slice this up in the next step. For example, if the connecting stalk protruded too far to the rear, then it would become structurally weak as fewer radial slices of the model would reach all the way out to its extremities. Remember: if you're using radial slice of wood then the further from the center you go, the flimsier your structure will become.
Once I had everything positioned and joined, I exported the model as a single STL file.
Step 3: Processing in 123D Make
I imported the STL file into 123D Make, a free app that lets you easily slice up 3D models into 2D vector files for laser cutting. I was actually using a preview version of 123D Make that isn't yet available to the public, so I was able to slice my model radially rather than just orthogonally. Don't worry, though! The public version of the software will be getting regular updates, so you should also be able to use these features in the coming months.
In 123D Make, I set the number of radial slices to 14, then fiddled with the radial center and rotational offset until I had the slices aligned with all of the fingers, so that each finger contained its own slice. I then tinkered with the number and position of the horizontal slices until I had something that looked sturdy and aesthetically pleasing and exported all of the components as EPS files.
On of the cool things about 123D is that it lets you readjust your material and object dimensions on the fly. This means that I could easily recreate this project in cardboard (which I actually did for several of my prototypes) or in thicker wood to make a much larger bowl. Heck, with enough plywood I could even make this thing into a chair!
I've included the EPS files necessary to make this bowl from 0.2" plywood or 0.157" cardboard.
Step 4: Lasering!
I used the Epilog laser cutter at the Instructables Lab to turn a big sheet of 0.2" plywood into a big sheet of 0.2" plywood with lots of oddly-shaped holes in it. I cannot stress just how much easier life is when you have a finely tuned laser that can cut through wood.
Step 5: Assembly
Once I had all of the pieces cut, it was just a matter of assembling the bowl. This is much like those wooden dinosaur skeleton kits that I'm sure we've all played with as children (and adults). 123D Make labels each piece for you, so it was much less of a frustrating jigsaw puzzle than you might expect; I just lined up each slot according to number and pushed them together.
The slight puzzle element appeared when I unthinkingly assembled 90% of the bowl and was then left with a few pieces that couldn't be added until I removed about 70% of what I'd already assembled. Ah well, you live and learn. This goes back to what I was saying earlier about trying to visualize a design in its entirety before you start manufacturing.
Step 6: Early Versions
Of course, what you see in this project is mostly the final iteration of this bowl. I made several prototypes from both wood and cardboard before I was happy with my design. Problems with some of the earlier versions included:
  • The bowl being off-balance, so that it tipped backward under its own weight
  • The bowl being too low, so that it obscured the hand
  • The hand not looking handy enough
  • The bowl not looking bowly enough
  • The stalk not looking creepy enough
  • The bowl angle being too steep, so things would fall out
Some of these are issues that I could have anticipated with careful planning and computer modeling, but for most of them I decided that it would be quicker and easier to just make a test model and see how I felt about it.
Step 7: The Final Bowl
And just like that, I had myself a handy little bowl, perfect for any desk, kitchen table or mad science laboratory.
Take a look at my Computer Assisted Gift Wrapping Instructable to find out how I made a presentation box for this bowl.
<p>So awesome!</p><p>It looks like some kind of dinosaur that has a built in bowl to collect rain- I don't know...</p>
<p>Good Idea</p>
<p>Hi PenfoldPlant,</p><p>Awesome design / Project.</p><p>I'm with everyone else below, would love to build my own. But the link to the store does not work, i assume that this is no longer available to purchase the kit.</p><p>As with others would love to get the final laser cut files, or dxf files for this project. </p><p>Have downloaded your eps, and pdf files. but they seem to be an earlier version than you final design.</p><p>Would be happy to pay for files, if need be.</p><p>Thanks</p>
<p>Hi PenfoldPlant, </p><p>I'm really impressed by this design, not only the creative idea to mend a bowl to a hand, but also how slim and how natural looking the design is.</p><p>I would like to build my own, but it seems that the template for the laser cutter from step 3 isn't the final form. That and I can't get a link to the store where i can purchase a kit to build one ; thus me having 2 questions : </p><ul><li> Is the kit a pile of already cut-out sheets of wood, or is there a simpler PDF file i can buy to laser cut it myself?<li>WHERE can i purchase such a product?</ul><div>Thanks a lot !</div>
hello sir I really wanna take this file . <br> <br>If you can send me this file, Please send me e-mail with this file <br> <br>I am Korean^^ my e-mail address is ( iyuk0318@naver.com) <br> <br>Many Thanks
Before I start i want to say fantastic job on the bowl. I love it. <br> I recently cut out and assembled the files both card and wood. The bowl looks more like one of your previous attempts and not the finished product. It just topples under its own weight and is much lower than the image above. Is this right?
Very nice looking art! congratulations on this accomplishment.
Thats handy
LOL at the caption, imagine what a nightmare this would be to cut by hand.
Excellent! I just made mine with my home made CNC router. Works pretty well on that with a 1/8&quot; bit. I rearranged to fit my sheet size better, but overall, a very cool build.<br><br>http://youtu.be/7uC_zN_wXVE<br><br>
Love this brilliant project! Thanks for sharing!
Hi PenfoldPlant,<br><br>Really like this project! WOW!<br><br>Do you know what Autodesk plans to do with 123D MAKE after it expires next month???<br><br>Thanks.
Check out the online version of 123D Make:<br />http://apps.123dapp.com/make/
Hey, thanks! Tested it. Works pretty smooth.<br><br>Still has a ways to go before we can do a project like the Hand Bowl.<br><br>Radial slices, please. :)
We're working hard to get an online version of 123D Make released. Since it's currently Mac-only, I suspect this will make lots of people happy.
Half way there! The online version is UP!!! It still has MANY limitations from relative to the MAC version. Also the import function seems to not function. I couldn't load the stl from the ible. But for the sample stl files it works great.<br>Stackable layers only for now it seems<br>No radial slicing<br>No orthogonal slicing with gaps.<br>But still a great step in the right direction!!!<br>
I tested the on-line version. Pretty nice. The import DOES work. It says files are limited to less than 5 MB though. Shouldn't be too much of a problem for simple objects.<br><br>I'm hoping to see that radial function there very SOON.
ewilhelm,<br><br>I am Mac-only AND not on-line in my workshop. So, an on-line-only version would create a huge obstacle for me to be a 123DMake user. UGH! Not so happy. To me, that's like having to borrow tools from someone else every time I need to use them. I would like to request that stand-alone copies be made available as well.<br><br>I really do like 123DMake and looking forward to the &quot;radial&quot; function.<br><br>Is there a place where users/makers can discuss 123DMake? The Autodesk blog does not seem to be very active.<br><br>Thanks.
ITS WONDERFUL, I HAVE MADE THE ASSEMBLY IN SOLID WORKS, ANYBODY NEEDS IT, FEEL FREE TO ASK
Did you recrete this particular project in to a SW assembly or did you create a slicing interface for SW?
i re-created the same project in solid works, just to play around before making it actually.<br>
send me you email address
O.O can I have a copy?<br>EPS files hate me.
Please ......how?
Its like Thing from the Adams Family !
After looking at the EPS files...I noticed that there are multiple pieces just...floating...like a small triangle or 2 that looked like it's supposed to be a part of a different piece.<br>Also,some parts are disturbingly thin in some places...is this supposed to be right?
Author - Can you also upload the EPS or DXF file which has elongated arms, i understand after making the Model that it is the smaller one which you have uploaded.... Thanx<br>
Impressive! Do you have the files as DXF's? <br> <br>
Can anybody help in giving the assembly instructions, the pieces are marked with numbers though it looks complicated to assemble, please help....Thanx
I'd like to make one in S/S either polished or Glass Bead Blasted.
You wouldn't happen to have these files in DXF format would you?
god i want one DA LASER to do leather working with
Keep an eye on our contests - I'm sure we'll be giving a laser cutter away again at some point...
yeah the did a while ago but so many entered that already had one or had access to one and were able to do far more advance things that drew in more attention
Kind of like this bowl as an entry in the shop bot challenge! :P
Penfold is an Instructables' resident. &nbsp;As such, he can <em>enter</em>&nbsp;any Contest, but &nbsp;he <u>can</u><u>not</u>&nbsp;win a prize. This is true for all Instructables employees.<br> <br> Projects like this raise the proverbial bar... and they deserve a wide audience.&nbsp;<br> <br> They are intended to educate, encourage and motivate... not to mention mind-boggle simple folks like me! ;-)<br> <br> <br>
Ohhhhh....... I didn't realize he was an employee of Instructables. But yes, this certainly does do all that you mentioned. Well done good Sir!
So this is a $45,000 laser cutter?
This is beautiful, in a grotesque and fairly disturbing way. I think one in a metal finish would also be impressive.
A metal one would be great, but our lab laser cutter isn't up to the task of slicing through metal. Maybe one day we'll upgrade to a super powerful laser cutter or a water jet cutter, though...
Perhaps the wooden one could be painted with a conductive paint and electroplated or electroformed.
Wild!!!
I'm going to take that as a compliment. Thanks!
It was meant as one :-)
Very cool project. Now to just go find where I put my laser cutt.. oh wait. How much weight can this hold by the way? I'd love to see a photo of it in action so to speak.
Good idea! I've now posted an action shot in the first and last steps of the Instructables. It's fairly sturdy!
Loving this.Don't suppose you could add the OBJ and STL files. I'd like to play around with it in Solidworks.
Sure thing! I've uploaded the STL file of the finished bowl (Hand Bowl 6.stl) to Step 2. Let me know how it goes!
I would buy one of these! I could see this in one of those expensive artsy catalogs!! If you ever decide to sell one (@ a reasonable, not artsy price) let me know! Very talented!!
Thanks, Bitsy! We're actually selling these already on the <a href="http://instructables.myshopify.com/">Instructables Store</a>. Check it out!
About This Instructable
63,880views
452favorites
License:
Bio: Artist in Residence at Pier 9, currently exploring a vast array of new tools with which to injure myself.
More by PenfoldPlant:Candy Hearts (made with real heart) Haggis Pops Explosive Cocktail Foam
Add instructable to:
