3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hand Bowl
Hand Bowl
  • last photo ←
Here's a small bowl I made from interlocking layers of birch plywood. I designed it using Poser, Blender and Autodesk 123D Make, then used a laser cutter to precisely cut all 40 of the pieces.
The bowl stands at about a foot in height and, despite being very light, is sturdy and extremely well balanced so it won't topple over when filled.
You can now buy a kit for this bowl on the Instructables Store. We're making these ourselves at the Instructables Lab, so supply will be limited!
Step 1Modeling the hand
Modeling the hand
The first step was to model and pose a hand to act as the bowl's base. For this, I used a piece of software called Poser by Smith Micro. Poser is a 3D modeling package that specializes in modeling and animating human bodies. It comes with a library of basic figures that can be easily posed using a very intuitive and beginner-friendly interface. I used one of Poser's default hand models.
When posing the hand, I had a few things to bear in mind. Obviously I wanted all of the fingertips to touch the ground at the same level so that the bowl would stand upright. I also had to think carefully about the way I splayed out the fingers. The fingers needed to provide as broad a base as possible while also looking natural and comfortable (Poser does nothing to stop you contorting its models into grotesque and unnatural positions, so this is trickier than you might expect).
A more subtle issue was to do with how I knew the model would eventually be sliced when I exported it into 123D Make. I knew from the outset that I wanted this bowl to made of radial slices converging somewhere around the base of the palm. This meant that I had to position the fingers so that they all roughly pointed straight outward from the same spot (so that each finger would contain a slice of plywood). Any major misalignment would make slicing the model impossible. This is an excellent example of how crucial it can be to visualize the entire design process of a project before you even start modeling.
77 comments
1-40 of 77next »
Mar 29, 2012. 9:04 AMxenobiologista says:
LOL at the caption, imagine what a nightmare this would be to cut by hand.
Mar 19, 2012. 1:39 PMccrome says:
Excellent! I just made mine with my home made CNC router. Works pretty well on that with a 1/8" bit. I rearranged to fit my sheet size better, but overall, a very cool build.
http://youtu.be/7uC_zN_wXVE
Jan 30, 2012. 4:12 PMGainEnergy says:
Love this brilliant project! Thanks for sharing!
Jan 12, 2012. 11:49 AMbsolo says:
Hi PenfoldPlant,
Really like this project! WOW!
Do you know what Autodesk plans to do with 123D MAKE after it expires next month???
Thanks.
Jan 27, 2012. 4:36 PMewilhelm says:
Check out the online version of 123D Make:
http://apps.123dapp.com/make/
Jan 27, 2012. 7:30 PMbsolo says:
Hey, thanks! Tested it. Works pretty smooth.
Still has a ways to go before we can do a project like the Hand Bowl.
Radial slices, please. :)
Jan 13, 2012. 5:16 PMewilhelm says:
We're working hard to get an online version of 123D Make released. Since it's currently Mac-only, I suspect this will make lots of people happy.
Jan 25, 2012. 3:46 AMFamilyGuy2006 says:
Half way there! The online version is UP!!! It still has MANY limitations from relative to the MAC version. Also the import function seems to not function. I couldn't load the stl from the ible. But for the sample stl files it works great.
Stackable layers only for now it seems
No radial slicing
No orthogonal slicing with gaps.
But still a great step in the right direction!!!
Jan 25, 2012. 10:08 AMbsolo says:
I tested the on-line version. Pretty nice. The import DOES work. It says files are limited to less than 5 MB though. Shouldn't be too much of a problem for simple objects.
I'm hoping to see that radial function there very SOON.
Jan 19, 2012. 12:02 PMbsolo says:
ewilhelm,
I am Mac-only AND not on-line in my workshop. So, an on-line-only version would create a huge obstacle for me to be a 123DMake user. UGH! Not so happy. To me, that's like having to borrow tools from someone else every time I need to use them. I would like to request that stand-alone copies be made available as well.
I really do like 123DMake and looking forward to the "radial" function.
Is there a place where users/makers can discuss 123DMake? The Autodesk blog does not seem to be very active.
Thanks.
Jan 18, 2012. 9:00 AMamjad831001 says:
ITS WONDERFUL, I HAVE MADE THE ASSEMBLY IN SOLID WORKS, ANYBODY NEEDS IT, FEEL FREE TO ASK
Jan 25, 2012. 3:49 AMFamilyGuy2006 says:
Did you recrete this particular project in to a SW assembly or did you create a slicing interface for SW?
Jan 25, 2012. 4:18 AMamjad831001 says:
i re-created the same project in solid works, just to play around before making it actually.
Jan 24, 2012. 12:55 AMamjad831001 says:
send me you email address
Jan 21, 2012. 1:01 AMjayko657 says:
O.O can I have a copy?
EPS files hate me.
Jan 20, 2012. 5:16 AMold.bodger says:
Please ......how?
Jan 22, 2012. 2:57 PMpaintphone says:
Its like Thing from the Adams Family !
Jan 19, 2012. 7:41 PMjayko657 says:
After looking at the EPS files...I noticed that there are multiple pieces just...floating...like a small triangle or 2 that looked like it's supposed to be a part of a different piece.
Also,some parts are disturbingly thin in some places...is this supposed to be right?
Jan 18, 2012. 9:08 AMamjad831001 says:
Author - Can you also upload the EPS or DXF file which has elongated arms, i understand after making the Model that it is the smaller one which you have uploaded.... Thanx
Jan 17, 2012. 6:01 AMold.bodger says:
Impressive! Do you have the files as DXF's?
Jan 16, 2012. 11:14 PMamjad831001 says:
Can anybody help in giving the assembly instructions, the pieces are marked with numbers though it looks complicated to assemble, please help....Thanx
Jan 16, 2012. 2:36 PMaccuproto says:
I'd like to make one in S/S either polished or Glass Bead Blasted.
Jan 16, 2012. 2:35 PMaccuproto says:
You wouldn't happen to have these files in DXF format would you?
Jan 10, 2012. 2:46 PMBlueeyeddevil says:
god i want one DA LASER to do leather working with
Jan 11, 2012. 6:52 AMBlueeyeddevil says:
yeah the did a while ago but so many entered that already had one or had access to one and were able to do far more advance things that drew in more attention
Jan 15, 2012. 5:13 AMHom3rSimpson says:
Kind of like this bowl as an entry in the shop bot challenge! :P
Jan 16, 2012. 7:39 AMbajablue says:
Penfold is an Instructables' resident.  As such, he can enter any Contest, but  he cannot win a prize. This is true for all Instructables employees.
Projects like this raise the proverbial bar... and they deserve a wide audience.
They are intended to educate, encourage and motivate... not to mention mind-boggle simple folks like me! ;-)
Jan 16, 2012. 8:07 AMHom3rSimpson says:
Ohhhhh....... I didn't realize he was an employee of Instructables. But yes, this certainly does do all that you mentioned. Well done good Sir!
Jan 12, 2012. 6:43 AMbtutty says:
So this is a $45,000 laser cutter?
Jan 12, 2012. 10:39 PMpaqrat says:
This is beautiful, in a grotesque and fairly disturbing way. I think one in a metal finish would also be impressive.
Jan 15, 2012. 10:34 PMpaqrat says:
Perhaps the wooden one could be painted with a conductive paint and electroplated or electroformed.
Jan 12, 2012. 9:48 AMCatTrampoline says:
Wild!!!
Jan 15, 2012. 12:59 PMCatTrampoline says:
It was meant as one :-)
Jan 15, 2012. 5:15 AMHom3rSimpson says:
Very cool project. Now to just go find where I put my laser cutt.. oh wait. How much weight can this hold by the way? I'd love to see a photo of it in action so to speak.
Jan 15, 2012. 4:46 AMJeff Yates says:
Loving this.Don't suppose you could add the OBJ and STL files. I'd like to play around with it in Solidworks.
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
201
Author:PenfoldPlant(Penfold Labs)
I'm a UK-grown tinkerer with a background in medicine and engineering, currently working (well, playing) as an Artist in Residence at the Instructables Lab in San Francisco. Please feel free to visit...
more »
