Introduction: Hand Crank Mechanical Toy
Picture of Hand Crank Mechanical Toy
http://youtu.be/buS14jK0n7g
Check out this video of the finished product.
Step 1: Concept
Picture of Concept
After finishing a few projects, I really wanted to build a little something for the kids to play with. The age difference will give this toy a different perspective for the kids. I expect the three year old to be intrigued by the mechanics and ability to make the worm move. And the one year old boy to use as a weapon and wreak havoc. Normal stuff.
This is not an original idea but I could not find any free plans on the line. I had seen one like this years ago in an antique store. The bad news is the box was closed so the mechanics were mostly magic. I'll include a pic that I used as inspiration.
Step 2: Materials
1-3' 1/4" dowel
1-3' 1/2" dowel
3/4" plywood piece
1•8 pine board
Tools
Miter saw
Hole saw
Drill
Biscuit joiner
Sanders
Paint
Drill press
Multiple clamps and piecemeal jigs
Step 3: Cutting Holes
Picture of Cutting Holes
I used a 2" holesaw. And a big half inch drill. In the end i only need 22 but I ended up needing more do to breaking a few
After cutting I rounded the corners to clean them all up.
Made a little jig to drill holes in the round part of the blank
Set each dowel to 2 1/2"
Step 4: Making the Cam Shaft and Box
Picture of Making the Cam Shaft and Box
This is the main part of the wiggle. After a lot of thought I decided to use a half inch shaft. Also to give the cam enough movement I would drill the center hole 3/4" from the outside of the circle.
Putting these on the shaft would be easier than I expected. After putting all my pieces on the shaft I lined them straight then made a straight line on the circles to give a reference point. Then turned each one about thirty degrees past the previous block. And I put a 10 penny masonry nail in between for a spacer.
Not too tuff.
The box is pretty straight forward.
Top 3 1/2"X14"
Sides. 3 1/2"X3 7/8"
Back. 4 5/8"X14"
Bottom 7 1/4"X14"
Used a biscuit joiner tool to make the butt joints strong enough to withstand some drops.
Before gluing it together make some holes. The eleven for the top will be from center out each way. Mine were 13/16" centers. These are pretty critical because this is where the worm rides up and down. The other holes you'll need are center of each side.
http://youtu.be/s8_OWOH3rQk
Little video of my first run.
Step 5: Put Together
Picture of Put Together
Gluing the box together is a no brainier but I dry fit it together to check my biscuits, shaft alignment, and top hole placement.
Fingers crossed
And glue
Step 6: Finishing Touches
Picture of Finishing Touches
After first putting the "worm" together and running, it was very obvious that the dowel needed feet. These are 2"X1/2"X3/4" center drilled and glued(last).
Crank handle and end piece both same plywood as the circles.
The head and tail were made from a piece of black walnut that I shaped on a lathe in one piece then cut in half.
Step 7: Paint and Assembly
Picture of Paint and Assembly
Had my little helper paint the "lollipops " and I painted the base. I didn't paint the inside because I love the look of the wooden mechanism.
Also the feet are the last thing you glue.
I hope this clearly shows how to build such. It has sparked my interest in wooden mechanical stuff. I love to hear comments and will answer any questions to the best of my abilities. I plan on entering the wood contest. Of coarse for prize but it would be nice to get the approval of "Ron Swanson".
Check out this video on YouTube:
donnyferns (author)2017-03-21
All of them are great!
MU5ICI4N made it! (author)2014-12-22
Thank you so much for the inspiration! I made a slightly modified version of yours (Mines a bit smaller, and I decided to leave the back of the box open). My 5 year old cousin should love this Christmas gift! Thanks again for the great instructible!
turtle keeper (author)MU5ICI4N2015-09-15
That looks so cute.
dtextor (author)2015-07-27
Present for god child, check. Thanks for the inspiration!
katik (author)2015-01-29
Nice work!)
Bverysharp made it! (author)2014-12-16
This is a wonderful project. I had heaps of fun making it. THANKS!
My only suggestion would be to make the ends a bit taller or the crank a bit shorter so that there is enough finger clearance under the crank. (A shorter crank may make it more difficult to turn for small kids.)
dalegribble (author)Bverysharp2014-12-16
that looks soooo great! Good job. Is that oak for the cams?
Bverysharp (author)dalegribble2014-12-17
The cams are some mysterious wood that I found by the side of the road. It looks for all the world like bamboo, but seems to be full of some kind of oil, smells like linseed. It is heavy, and very brittle. I have no idea what it is. The end grain was prickly and hard to smooth over. The cam followers are some kind of dense fine grained Australian Hardwood, and I would probably use this for the cams next time. Thanks for your kind praise!
Jim Davidson (author)2014-12-05
Very cool toy. I like it alot. A little hint in using your hole saw...When cutting a circle, drill only half way through the material, then flip it over an drill it again. In this manner you will get far less splintering, save a lot of tedious sanding and as an added bonus...the circles are much easier to remove from the hole saw.
I use this technique, but I will go through one side until the pilot drill in the middle just breaks through the bottom side. Then you have a center point to go off of and make sure the hole saw lines up side to side.
user866753 (author)2014-12-05
Great toy for kids! Wooden and sturdy, interesting mechanics they can study and figure out while also simply entertaining. Clear and simple instructions.
kpendragon (author)2014-12-04
Awesome idea. Love the 3 year old 1 year old comparison. I sooo hear you
nemalim (author)2014-12-04
wow! this is great!
Chickim (author)2014-12-04
So cute! Thanks for showing how you made it. I am a newer woodworker and think I could tackle this project for the grandkids for Christmas. You should also enter the Homemade gifts contest because this is better than most posted already IMHO.
wambs8 (author)2014-11-28
My kid would love that. You know with a slight modification and a electric motor that would make a awesome back/foot massager.
Ayush Sharma (author)2014-11-28
That Looks an Amazing Idea Which would be totally loved by children!
MU5ICI4N (author)2014-11-27
Awesome project, awesome instructable! There's just something about wooden mechanical toys that is so appealing. You've got my vote :D
Eric Rocher (author)2014-11-27
Nicely done. I have a love for wooden mechanical items, too. Mechanical movement toys are so interesting and the wood has such a warm and organic feeling. I could see this becoming a family heirloom treasure for a family that has lots of kids. Plus, I'm not ashamed to admit a small bit of wood shop envy. Good job!
nancygribble (author)Eric Rocher2014-11-27
thanks. I'm trying to find my next project already. It is a very fun woodworking mediu
Madrynense (author)2014-11-27
Exelente trabajo!!! esta muy bueno y original.
Para estas fiestas espero poder realizar uno a mis hijas, tu trabajo fue de gran inspiracion
About This Instructable
38,182views
513favorites
License:
More by dalegribble:Skateboard LightFire Pit Coffee Table Straightener Station
Add instructable to:
