3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hand Cranked Document Shredder
Step 5Weld it Together
Weld it Together
The tricky part was welding it without melting the plastic bearings on the shredder.
I draped a soggy wet rag over the metal between the weld and the plastic bearings. Then after welding I mopped at the hissing welds to chill them as soon as I could without cracking them.
I used the shop's wirefeed welder. To make welding easy, use Miller's online welding calculator to find out what amperage, gas pressure, wire feed rate, etc. for the material and type of weld you're doing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
