Parts Needed:
PVC Cement
30" 1-1/4" PVC
36" 1/2" PVC
1x 1-1/2" ABS Wye Fitting
1x 1/2" PVC Slip Cap
1x 1/2" PVC Threaded Cap
2x 2 1/4" PVC Slip Cap
3x 1-1/2" x 1-1/4" PVC Bushing
1x 1/2" Slip to Threaded Adapter
1x 1/2" Foam Pipe Insulation
1x 1/2" Elbow
1x 1-1/4" x 1/2" Reducer Coupling
Cost:
I purchased all of the parts new for just under $23. I did not have to buy any of the tools.
Tools:
Dremel or Sand Paper
Scissors
Pipe Cutter or Hack Saw
Drill
Disclaimer:
This dredge is not my original design, it's based on this: http://www.youtube.com/watch?v=YCozzarSk5A
Please note I am not responsible for anything you do, so please only use my instructions as guidelines. Use proper safety equipment and common sense. Also check with local laws to make sure you're allowed to use a dredge in your local area.
Remove these ads by
Signing UpStep 1: Step 1 - Drill Cap, Sand 1/2" Adapter
The easiest way to find the center of the circle is to place a square over the circle, lining up the the point on the edge of the circle. Then mark the spot where the square goes outside of the circle. Draw a line between two marks. Repeat this again by moving the square part way around the circle and drawing another line. Where the two lines intersect is the center of the circle.
For more in-depth instructions:
http://www.mathopenref.com/constcirclecenter2.html
Next you'll want to use a dremel or sand paper to sand the PVC Bushing (1/2" slip to 1/2" threaded) so it can fit inside the 1-1/4" pipe.
Visit Our Store »
Go Pro Today »
I was thinking of using one way valves like you did, and using a hose instead of a collection chamber, so I could pump the material from the crevices directly into a sluice or gold pan but I should be able to easily modify the current system to work with valves.
I like your idea on the valves though!
I'll try this, even without a video. GOOD WORK!!
At first I was wondering why you didn't have any screening to limit the size of particles and rocks, but after thinking about it for a few seconds it makes perfect sense... the 1/2" in tube prevents anything larger than ball bearing size from coming, so you're mostly just gettting sand and small flakes...
Makes me wish I were in gold country!
Otherwise, looks great.
Reminds me of the Dayze up at Shasta College in Redding, we used to pan
up at our spot camping on weekends for beer and food money in the 90's, could not use a dredge or fish on The Sacramento from the Chem Spill (trainwreck) but could bring up black sand with SCUBA gear ( Hope I did'nt Dame My Bramage..twitcth-twicht !) Our "Assayer" in Redding seemed to give us let than
actual worth for our flake and few nuggets.(break a point off a #2 pencil, About all we found) At today's Gold value, would have lived like Kings ! ( Teriyaki Burgers for
the whole class at the Cafeteria !) Fun Times!
