Hand Held PC
Published
Introduction: Hand Held PC
Hi all..
This is one of my creations made out of boredom, it consists of:
  • Vtech V Smile (case)
  • 5.6" TFT LCD
  • Dell Thin Client PC FX130 (1Ghz VIA,1 GB ram, 1GB SSD, Win XP nlited)
  • Arduino Mini Clone
  • 12V Lithium Rechargeable Battery
  • Some putty
  • Hot Knife
  • Wrist action (sanding!!)
  • Broken PS3 pad
  • Hot Glue
Step 1: Get Your Stuff!
I got the Vsmile off Amazon for around £20, the Arduino set me back £6 and got it off ebay along with the thin client PC for £20. The screen cost me around £30 and the 12V battery £10 and got them off ebay also. I had a faulty PS3 pad which I used for the buttons and the analog stick.
Step 2: Rip Everything Apart, Cut, Mold, Stick and Sand!
I had an old PSP screen lying around so I used this as a template to cut the screen out. I cut the buttons on analog stick out of the PS3 pad out and used the excess plastic to fill in the gaps on the Vtech shell..
Step 3: Tweaks & Testing
The Ardunio clone didn't have any boot loader so I had to get the old trusty GQ4-X programmer and flashed the clone though the ICSP port.
The Arduino micro clone I had didn't have the functionality of changing the usb function other than a serial port emulation so I had to write two programs instead of one.
The Arduino program basically captures the buttons and analog stick and sends the data via serial
Analog X->A0
AnalogY->A1
Other buttons D0 <-> D8
Here's the code for the Micro
// These constants won't change.  They're used to give names<br>// to the pins used:
const int analogInPinY = A0;  // Analog input pin that the potentiometer is attached to
const int analogInPinX = A1;  // Analog input pin that the potentiometer is attached to
int outputValueY = 0;        // value output to the PWM (analog out)
int outputValueX = 0;        // value output to the PWM (analog out)
int centreY = 0; //Callibrate
int centreX = 0; //Callibrate
int Ypos = 0;
int TempY = 0;
int NegY = 0;
int Xpos = 0;
int TempX = 0;
int NegX = 0;
// constants won't change. They're used here to
// set pin numbers:
const int buttonup = 2;     // the number of the pushbutton pin
const int buttonright = 3;     // the number of the pushbutton pin
const int buttonleft = 4;     // the number of the pushbutton pin
const int buttondown = 5;     // the number of the pushbutton pin
const int buttonDiamond = 9;     // the number of the pushbutton pin
const int buttonTriangle = 8;     // the number of the pushbutton pin
const int buttonRed = 7;     // the number of the pushbutton pin
const int buttonYellow = 6;
const int buttonAnalog = 10;
const int buttonMode = 11;
const int ledPin =  13;      // the number of the LED pin
const int led2Pin =  A2;
// variables will change:
int dirState = 0;         // variable for reading the pushbutton status
int buttonState = 0;         // variable for reading the pushbutton status
int CTX;
int AnalogNegs = 0;
int PadMode;
int Fader = 0;
int FaderDir = 0;
void setup() {
Serial.begin(19200);
  // initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
pinMode(led2Pin, OUTPUT);
  // initialize the pushbutton pin as an input:
pinMode(buttonup, INPUT_PULLUP);
pinMode(buttondown, INPUT_PULLUP);
pinMode(buttonleft, INPUT_PULLUP);
pinMode(buttonright, INPUT_PULLUP);
pinMode(buttonTriangle, INPUT_PULLUP);
pinMode(buttonDiamond, INPUT_PULLUP);
pinMode(buttonYellow, INPUT_PULLUP);
pinMode(buttonRed, INPUT_PULLUP);
pinMode(buttonAnalog, INPUT_PULLUP);
pinMode(buttonMode, INPUT_PULLUP);
CTX = analogRead(analogInPinX);
centreY =  map(analogRead(analogInPinY), 0, 1023, 0, 254);
centreX =  map(analogRead(analogInPinX), 0, 1023, 0, 254);
Callib;}
void Callib() {
  //TRY!! Callibrate Centre
centreX =  map(analogRead(analogInPinX), 0, 1023, 0, 254);   }
void loop(){
  // read the state of the pushbutton value:
  outputValueY = map(analogRead(analogInPinY), 0, 1023, 0, 254);
  outputValueX = map(analogRead(analogInPinX), 0, 1023, 0, 254);
  Ypos = 0;
  NegY = 0;
  TempY = (outputValueY - centreY);
  if (TempY > 5 || TempY < -5) {
      digitalWrite(ledPin, HIGH);
  NegY = TempY < -5 ;
  Ypos = TempY & 254;
  Xpos = 0;
  NegX = 0;
  TempX = (outputValueX - centreX);
  if (TempX > 5 || TempX < -5) {
  NegX = TempX < -5 ;
 // if (TempX < -83){TempX = -84;}
//  if (TempX > 83){TempX = 84;}
  Xpos = TempX & 254;
//  Serial.println(TempX);
//Serial.println(Xpos);
  dirState = 0;
  dirState |= (digitalRead(buttonup) ^ 1) << 0;
  dirState |= (digitalRead(buttondown) ^ 1) << 1;
  dirState |= (digitalRead(buttonleft) ^ 1) << 2;
  dirState |= (digitalRead(buttonright) ^ 1) << 3;
  buttonState = 0;
  buttonState |= (digitalRead(buttonTriangle) ^ 1) << 0;
  buttonState |= (digitalRead(buttonDiamond) ^ 1) << 1;
  buttonState |= (digitalRead(buttonYellow) ^ 1) << 2;
  buttonState |= (digitalRead(buttonRed) ^ 1) << 3;
  buttonState |= (digitalRead(buttonAnalog) ^ 1) << 4;
  int d = (digitalRead(buttonMode) ^ 1);
   if (PadMode > 0) {
     //delay(30);
     digitalWrite(led2Pin, HIGH);}
   else{
   digitalWrite(led2Pin, LOW);
  //if (PadMode = 0) {analogWrite(A2, 0);}
  if  (d > 0 ){
    PadMode = (PadMode ^ 1);
  //    // PadMode = 1;
    // digitalWrite(A2, HIGH);}
     //return;}
   while ((digitalRead(buttonMode) ^ 1) > 0) {
   }        delay(3);}
    buttonState |= PadMode << 5;
  AnalogNegs = NegX << 0;
  AnalogNegs |= NegY << 2;
  Serial.write(0xFF); //sync
  Serial.write(dirState);
  Serial.write(buttonState);
  Serial.write(AnalogNegs);
  Serial.write(Xpos);
  Serial.write(Ypos);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (dirState > 0 || buttonState > 0) {
    // turn LED on:
 //analogWrite(A2, 20);
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
    Callib;
   // delay(3);
  delay(2);
I've used a sync byte to synchronize the serial data to the FreeBasic program. I also added an LED that sits in the centre button which is used as a 'Mode' button to give another layer of control.
The FreeBasic program converts the serial data from the Arduino into to keyboard keystrokes, it's run upon start-up of windows as a background task.
Thanks to Ben Heck for the inspiration!!
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    "The Ardunio clone didn't have any boot loader"
    Sods law that is... I have the same problem with all the clones I buy... So I've made a programer from a cloned arduino... lol
    Nice build. I want one now :(
    Ha, you get what you pay for I guess!.. Thanks for the comment.
