Step 6Connect the switch
Connect your switch between one of the leads from the battery holder and your LEDs. Connect the other battery lead directly to the LED wire.
Again check to make sure that everything is wired the right way before soldering into place.
Try to keep the leads as short as possible so you don't have to worry about them catching on stuff. If you have extra wire you can wind it around the armature wire before soldering.
Hot glue the switch into place. I also covered the wire with glue to prevent shorts, keep it from catching on stuff, and because hot glue is one of the most fun ways to get first degree burns.
Add Comment
