Step 3Shape the Candy
Lace edges - do these first. Squeeze out a little dot, touch it to the parchment (I started in the middle top of the heart), lift a bit, squeeze another drop, touch down in the next circle. Keep going all the way around. It doesn't need to look perfect, but try to keep it even.
Polka dots/polka heart, center heart of 'target' shapes - do these second. For polka dots it's like the lace edge - just squeeze out more candy and put it in the center of the circle. For hearts do two dots - the two top parts of the heart - then use your toothpick to drag the candy out to the edge of the hear shape.
Lines - do these next. Don't touch the tip of the bottle down - keep it cleaned off with a paper towel. Start squeezing a bit, let the candy touch down to start the line, then slowly squeeze and drag to the end of the line - hovering above the parchment. When you get to the end stop squeezing and the line will stop.
Open areas - fill in the rest of the shape loosely with the candy, then use the toothpick to drag it to the edges and completely fill in the shape.
I found I was able to keep melted candy of all four colors going all of the time - I would keep the four bottles filled, and when I wasn't using a color I would keep it inside the microwave. The occasional 30 at 50% kept them flowing well, and the microwave stayed warmer than the ambient kitchen temperature. After enough re-heats the candy starts to get stiffer but you can always mix in some fresh if this happens.
comments
Add Comment
technoplastique (author)
says:
Add Comment
