loading
Step 2: Measuring Up Your Project
When drilling the holes just make sure that the diameter of the hole is the same as the nail or peg your using or else they will either not fit or fall out.  The nails I used were 1/16th of an inch in diameter and 1 - 3/8ths inches long . I spaced them at 3/16ths of an inch apart, which should be your minimum for the yarn to work effectively around the pegs without limiting the yarn or your hook around them. (The yarn in this case was less than an 8th in in diameter.)
Measure once and then again as when working this close, it doesn't matter when using every other peg (3/8ths in apart ) for larger yarn the difference is not noticed as much but I did get one hole drilled too close to another, and it makes a slight change in the closeness of those two stitches coming off that  peg.  I have a size 8 foot. You may need more pegs for a larger foot.
The thickness of the letter gives enough room to figure in how many 8ths you need at 3/8ths between every other peg and get your diameter around the ring. and then remeasure in between  to make sure your 3/16ths are equally distant apart.  Some find that a compass with a pencil or a sharp pair of points (see photo) are good for fine work.
I just jumped in and marked off the points but next time I will be more careful.  For an average adult size foot, I found that you need to have at least 14.5 inches circumference round for your peg points. (minimum)  I ended up with a total of 74 holes, but started  out only useing38(every other one,  and then added a few pegs on the corners to get me up to 40  (make turning the heel easier on closer pegs) for the correct width starting at the toe. (14.5 inches is equal to 116 - 8ths  I somehow came up with 114.  38x 3-8ths, because my corners were not spaced evenly apart in measuring, but I had enough pegs to get through the project.   I did gradually add pegs for the heel turning and then spaced in between every other empty hole. Then gradually worked up to all but 8holes with a peg.  Also when increasing the number of pegs for the heel, I did decrease a few for the ankle and then replace the every other peg to start on the calf.  (Photos of the sock included in next few steps)
I will add more photos and info when I try out the other letter shapes.
<p>I love this idea. I'm going to have to try this. Thanks for sharing!</p>
<p>Great instructable and a great idea, you clever clogs! I've found the same problem with knitting looms that have been bought. We always made our own as kids - my first one was a cotton reel four pin that every kid made in my day (yes, dinosaurs roamed the Earth :P) and I've made other, more complex ones since then, but using a letter D shape hadn't occurred to me. Kudos and thanks for sharing!</p>
<p>really great idea!</p>
I was going to do this for the first letter of my name, but then I remembered my name is zoe....
<p>I had kept this sight on my computer from your first time up, wow you have reaally made it more do able instructions, gooing out toget my letter this week. I have a wide size 7 dhoe so your 8 should work perfectly. love thayt I do not have to buy special pegs to make and it is adjustable</p>
I'm afraid to be old and trip or something and fall and stab myself in the face
file the tip of the nail
<p>Wow! Nice instructable!</p>
<p>I really like this idea! You had the same problem I had. The cheap looms were all large gauge made for the big chunky yarns. The ones made by <a href="http://www.knittingboard.com/" rel="nofollow">http://www.knittingboard.com/</a> are much better and available in most if not all craft stores. They have a specific sock loom, the sock loom 2 is 3/8&quot; gauge for making socks with worsted weight yarn, and the All-In-One loom (the one I just got), is the same guage as the sock loom 2 and is adjustable. I may make one of these letter looms too.</p>
<p>I made one of these for my dads girlfriends son, he like loom knitting.</p>
Thank you for the hard work <br>http://post.zamoserver.com
Neat idea. I've tried knitting, but prefer crochet. I have not tried loom knittig though. That might be more appealing. <br><br>I too like the idea of using letters for a loom.<br><br>Life is busy right now, so it may be awhile before I post my next instructible. <br><br>Thanks for stopping by.<br>
I found a heart made of braided chord. So thought this would be a great opportunity to use the four pin French knitting to make knitted chord and make something decorative out of it.
That sounds very cool! Any chance you might have a picture? Would love to see it!
Sounds like fun. I'm looking forward to seeing it. :o)
Glad you liked the made by hand, hand knitter. I am currently crocheting a hat for chemo patients. So I love to crochet also just for fun. Sometimes you just have to have the right moment to create an instructables, so don't force it. <br>I have one started but not finished. If I push it, I know it won't be the way I want it.
this is a good idea to come up from the underside. So you don't make your pegs permenant? Aren't the nails sharp.....I mean don't you scrap or poke yourself? And do you snag the yarn at all on the points....some look like they might snag it by not being smooth.
I nail the nails &quot;heads up&quot; -works just fine. Great Instructable oh Creative One :0)
Did you ever do an O? what about the P and the Q?
I'm floored. Good work!!
cool idea
Oh my. What kind of yarn is that?! I must have it.
How big is that D from top to bottom? Congrats on thinking out of the box on this one!
What a great imagination!! I'll look at these wooden letters in craft shops with a different perspective now. <br>This would be a fun way to introduce knitting to a young person. <br>If you buy two 'D's', you could knit both socks at the same time. <br>When I'm using up small amounts of leftover wool, I sometimes cast on the stitches using two sets of needles (of course!) and knit both mitts at the same time and often from both ends of the ball to be sure I don't use too much on one mitt.
What a great idea! I just love knitting socks. I did get two more Letter D but am working on a variant so I can get it to expand up to my thigh and make Long Johns for winter. I love wearing them under my pants in the winter but each year I have purchased some, they get thinner and cheaper material. Only if you happen to look into a hunters catalog will you find the heavy duty ones and sometimes these are too thick or itchy. By having control over the knit and the fiber, I can make something nice and warm and wearable.
I almost think you could do it by putting an outer row of pegs and then adding them into your rows as a deviation zigzag of two or 3 outer pegs for every 1 inner peg at the point where your knee bends, it will look a lot odd until you take it off the loom, or it may not even work, but it would be fun to see how it turns out...<br><br>Imma need a really big D...
I never thought of knitting my own Long Johns. I have half a dozen pairs mostly from thrift shops but I didn't see any in those shops this past winter. Couldn't get through an Alberta winter without them!!
I entered the maker bot challenge. Please vote for me. I have many projects that could use this tool.
Right now I'm trying to learn how to knit socks on dp needles and have never used a loom but I think this is a wonderful and inventive way to construct your own using found materials, thank you.
Did you try the letter O? If so, do you like it better or worse? How about P?
I really like this tutorial! I love to knit socks in the round on a large circular using magic loop, but might give this a try and then take the idea to my guild for them to see!
I have never tried magic loop, so we both have something new to try. If you do, I would love to see your knitter.
Great instructable! I have lusted after circular knitting machines, they are very pricey antiques and far out of my budget. I can knit circular but socks take such a long time. I really want to try this out. I have been spinning alpaca and it would make great socks!
I really enjoyed making socks this way. I am going to try long Johns next just because I am not happy with the quality in the store are either too thin or hunters type are too heavy. It will be one of my near future quests.
I am working on a variation with another Letter D to see if it makes a difference in the over all design. Can't wait to try the Q also.
You can count on my vote after May 1st. I marked it on the calendar!! <br>
Thanks for your support.
I'd love to see how you transform your tube into a sock? Does it have a toe and heel or is it just a tube when it's done?
I updated my photos. I was so excited about finishing my first sock and that it fit very well. I still have another to go but set it aside to get my photos done. If you can, please be the first to rate my project.
That is coming soon. I have photos of the heel and the longer length, but thought an instructional about making the sock would make a great add on. Thanks..I am going to add photos of the drill bit and segmenting off the sections here. So its not final. Hope you will rate my instructional.
I tried the french knitting but never was very good at it mostly because I always kept my line pulled too taught... Nice instructible I like the idea of using the letter as the loom it makes it almost customized for people if you use the letter their name starts with.
I like your idea, as I have obtained several shapes that I thought would work as knitters. The Straighter ones like L for instance would make good straight knitters for making panels. I thought of using C but then the knitting would fall to the outside of the letter making it a bit trickier to handle, but would give you 2xs the C around and back for your tube. Maybe a pant leg?
About This Instructable
83,991views
205favorites
License:
More by NaturalCrafter:Hand Make Sock Knitting Loom
Add instructable to:
