Hand Motion Controlled R/C Car
 by frank26080115
This is a must-do hack for any cheap R/C car, it uses the tilt sensing switches I made so you can control a car just by tilting the controller like a wiimote.
There are many possibilities with this hack, for example, you can turn the controller into a base-less joystick, or put it on a helmet and control it with your head.
this will also work for R/C tanks (or other two motor drive stuff) except the switches needs to be placed diagonally
Another possibility to explore is making a mini segway, if you can get the tilt switch sensitive enough and the controller mounted onto the car (the car must be wheelie-ready). This might not work so good.
Below is two pictures of the car I'm working with (the front end spins, not steer, but it is not a problem with some practice)
You will need:
  • r/c car
  • tilt sensing switches (see step 2)
  • hot glue gun
  • soldering iron
  • wires
  • some pvc pipe (see step 4)
  • collection of hand tools
Demo Video:
Step 2: Opening and testing the controller
First you need to figure out how the controller works.
Open it up, save and map out each screw
If your antenna wire is moving around, hot glue it down.
You need to use a multimeter to test what connects to where, have fun at it. What I found in my controller was 4 metal flaps, all connected together, which presses against 4 jumper wires underneath them. The 4 flaps are connected to the negative terminal of the battery, this makes it really easy to hack.
You might also have one with buttons instead of sticks, I have no idea how those work so you need to figure it out.
If you are unlucky, and each flap or button are not connected to all the other buttons, then you might need to use 4 tilt sensing switches, except make them SPST.
DO NOT BE TEMPTED TO DO ANYTHING TO THE COIL THINGY
Step 3: Adding some wires
Now you know what needs to be connected to what, solder some wires to those places. (colours of the wires doesn't matter)
Now try and control the car by touching the wire ends together, if it doesn't work, figure out why, it could be a simple bad solder joint.
Drill some small holes so the wires can get out, put the wires though them, take care making sure that the wires won't be bothering any of the mechanical parts inside the controller (such as the stick or the metal flap, or stopping the casing from shutting completely).
Close the case, test it again by connecting the wires and by using the sticks, it's better to have both of control methods working.
If you want to make the controller one big base-less joystick, cut a large dowel (or pipe), and attach it to the top or bottom of the case before you close the case. Make sure everything fits.
Below are three examples of what I soldered
Step 4: Mounting the switches
If you are lazy, just attach the switches to a block of wood.
What I did made it completely adjustable, you need:
*3/4" pvc pipe
*3/4" pvc pipe cap
*1/2" pvc pipe
*some tape
Put the tilt switch that will control the forward/reverse on to the face of the 3/4" pvc pipe cap.
Cut a segment of 3/4" pipe, and drill 2 holes for the antenna to go through, and in my case, one of them might need to be bigger.
Cut a small stub (1-1/2" to 2" long) of 1/2" pipe, attach the steering tilt switch on the side of the pipe
Put lots of tape on the 1/2" pipe stub, and insert it into the 3/4" pipe, it should fit snuggly
Put the 3/4" cap with the tilt switch on the other end of the 3/4" pipe
Put the entire assembly onto the controller
This way lets you adjust the switches every way possible
Look at the diagram and pictures if you get confused
Step 5: Hooking up the switch
You might have noticed I put spade connectors onto the switches, you can do this too, but you don't really need to.
Wiring is simple enough, loop the wire around the screws and then tighten them.
If you have one wire from the negative battery terminal like me, put a switch on it, I would but I didn't have any switches handy.
Step 7: Mini Segway Idea
This is just an concept
If you have a car like mine then you can try making a more sensitive tilt switch and mount the controller right on the car mount it in a way that the switch is neutral when the car is almost balanced on its rear wheels
If the car leans forward, the the switch will make the car move forward, making it lean back
if the car leans back, the switch will make the car move in reverse, making it lean forward.
If everthing is balanced, theoretically the car will remain in place and balanced on its rear wheels
If the front is slightly heavier, then the car will start to move forward slowly while trying to stay balanced
If the rear is slightly heavier, then the car will start to move backwards slowly while trying to stay balanced
This will only work if the car doesn't over react and the switch works fast enough.
1-40 of 66Next »
rc trucks man says: Aug 24, 2011. 12:09 PM
Hey tropical rc, I have a heng long rc tank i'm going to try this out.
_________________________________
rc tanks man
Venemot says: May 14, 2011. 3:59 AM
I think hacking the rc with the buttons is much more easy....you just have to find two of its four wires which are actually connected to the rc and then soldier wires to them...!!!
The Renaissance Man says: Jan 12, 2008. 10:10 AM
You should make the remote so it's attached to your wrist
DELETED_yoghurtsniffer in reply to The Renaissance ManMar 15, 2008. 1:06 AM
(removed by author or community request)
mettaurlover in reply to DELETED_yoghurtsnifferMay 5, 2008. 2:54 PM
mercury is liquid. it. is. LIQUID. and what passes through liquid? ELECTRICITY. so, can you figure it out now?
Venemot in reply to mettaurloverMay 10, 2011. 11:38 PM
well mercury doesnt conduct electricity because it is liquid....it conducts because it is metal...the only metal that is liquid at room temperature.....and only polar liquids or solutions having ionic compounds as the solute can conduct electricity....!!!!
mettaurlover in reply to VenemotMay 11, 2011. 4:58 AM
Can you understand the concept of time, or maybe internet etiquite?
frank26080115 (author) in reply to mettaurloverMay 5, 2008. 4:02 PM
are you saying all liquids conduct electricity?
dombeef in reply to frank26080115Aug 17, 2008. 8:30 AM
yea he is but he is wrong all liquids don't conduct electricity.
dunnos in reply to dombeefMay 9, 2009. 2:38 AM
grammar fail, now you are stating that not even a single liquid conducts electricity :P
dombeef in reply to dunnosMay 9, 2009. 8:37 AM
Sorry but that was a looong..... time ago.
whitish in reply to DELETED_yoghurtsnifferApr 11, 2008. 9:40 AM
wouldn't the mercury one work the same as the ball one only the ball is mercury? I don't know if mercury conducts so well though.
Polymorph in reply to whitishSep 2, 2008. 10:11 AM
Mercury conducts well enough, it is a metal. The difference is the ball one can bounce when it makes contact. The mercury just engulfs the connections. However, that isn't so important in this case, I think.
DELETED_yoghurtsniffer in reply to whitishApr 11, 2008. 9:58 PM
Venemot in reply to DELETED_yoghurtsnifferMay 10, 2011. 11:43 PM
by the way you can make the sensor your self....and instead of using a metal ball or mercury you can use a solution of water and lots and lots of salt.....that will work....by the way this idea struck my mind while reading the comment and i havent tried it yet but i will try to post an instructable as soon as i make it.
Venemot in reply to VenemotMay 10, 2011. 11:45 PM
but the sensor would be quiet big it wont be really very easy to make a very small one although it can be made with smaller tools and lots of patience.
DELETED_yoghurtsniffer in reply to whitishApr 11, 2008. 9:45 PM
Venemot in reply to DELETED_yoghurtsnifferMay 11, 2011. 10:45 PM
Although i am not sure how the mercury motion senser works(probably because i have never seen on)i think you can make it by taking the wires of the circuit you want to complete with it and sticking them at close distance on one side of of a thin tube...do the same on the other side as well.so when the tube is tilted to one side it will engulf one pair of wires and complete the circuit...i am going to make the one with the ball bearings and i will post an instructables as soon as i find ball bearings and make the sensor....!!!
EnigmaMax in reply to The Renaissance ManJan 22, 2008. 9:12 AM
hehe, thats a good idea
amithav says: Aug 20, 2008. 12:35 AM
Fine Idea...anyway can we control this car using our Computer, Flight Joystick...
Venemot in reply to amithavMay 10, 2011. 11:34 PM
you can easily control it via pc with the help of a 4 relay phidget...well they are a bit hard to find but if you do there is going to be just a little soledering and a little programming.you just solder two wire each to the +ive and -ive sides of each button and attach the wires to the relays in the phidget then you do the programming for it(which i cant do properly,actually i dont have a phidget,yet)and you are done.
Prof I.tiki says: May 9, 2009. 12:17 PM
hey i wonder if this theory will work with a bigger R/C vehicle.
TropicalRC in reply to Prof I.tikiSep 16, 2010. 1:36 PM
I have just managed to do this with the Heng Long RC Tanks . They are the 1:16 scale tanks so I'm not sure if this is the size that you mean. If it is let me know as I can help you with this!
Riojelon says: Dec 22, 2009. 4:16 AM
Your concept can bedone by somehow adding this instructable's circuitry into your rc. I dunno how to do it, though
astro boy says: Dec 20, 2009. 6:45 PM
 GRRR my stupid car has 2 tiny solder tabs and so i had to take the buten of to use them and the solder wont eaven stick! >:0
Bowenj says: Jul 21, 2009. 10:49 AM
Man, if you could do this with an iphone!!!
astro boy in reply to BowenjDec 19, 2009. 9:52 PM
 you might if it will let you touch that kinda info via the usb make a custom plug or it could send it to a mac or pc and then the mac or  pc would control via serial port
b3nji says: Jul 12, 2009. 2:13 AM
u should of used a better rc car because this car has no proper steering.
Sagar Gondaliya says: Jan 30, 2009. 7:12 PM
what happens if I mess with the coil? *innocent look*
11richie21 in reply to Sagar GondaliyaJun 23, 2009. 7:12 PM
if you mess with the coil a snake comes out!
Sagar Gondaliya in reply to 11richie21Jun 24, 2009. 6:31 AM
a little late but still funny. I messed with the coil and it just changes the frequency of the remote. @coltonpo18: it wont do any physical harm, only mental because of how frustrating it is to get the right frequency again. lol
coltonapo18 in reply to Sagar GondaliyaApr 16, 2009. 6:34 PM
instant death.
11richie21 says: Jun 22, 2009. 1:12 AM
what if I don't have an on off switch?
Bert99 says: May 2, 2009. 11:54 AM
I have that same rc car
treize7 says: Jul 29, 2007. 1:18 AM
what is a segway?
Sagar Gondaliya in reply to treize7Jan 30, 2009. 7:20 PM
omg
Jr Hacking kid in reply to treize7Nov 2, 2007. 10:16 AM
go look it up
Sagar Gondaliya says: Jan 30, 2009. 7:17 PM
you could turn diagonally if you hooked up a negative wire to each tilt switch
Resident Expolsives Expert says: Dec 16, 2008. 6:51 PM
Coffee bean says: Oct 14, 2008. 5:53 PM
sweet now build it into to a glove and add it to a fullsize tank
1-40 of 66Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
