Introduction: Hand Saw From Reciprocating Saw Blade
Picture of Hand Saw From Reciprocating Saw Blade
Make a handheld saw.
It can be used for light sawing, cutting packing tape on boxes or opening envelopes.
Step 1: Create Handle
Picture of Create Handle
Parts:
- duct tape
- reciprocating saw blade
Create a handle using the duct tape. Wrap it around the reciprocating saw blade.
Cover about half the blade and be sure to wrap it around several times. This will create a cushion against the teeth of the saw blade when it is gripped.
BeachsideHank (author)2016-05-02
Is your next spoof going to be how to make tape for a saw blade handle? ☺
matt392 (author)BeachsideHank2016-05-02
No, tape is readily available at Home Depot, so that won't be necessary. ☺
joekurm (author)matt3922016-05-02
Saws are readily available at Home Depot, so this DIY is irrelevant.
But seriously, if you are in a bind, this works!
BeachsideHank (author)joekurm2016-05-02
I did use a variation on this trick though; separating a pair of kitchen wall cabinets from the frame anchor screw that was buried beyond retrieval and was holding them fast. Only difference was I used a pair of locking Vise Grips as the handle, it was indeed a lifesaver that day.
matt392 (author)BeachsideHank2016-08-14
Great idea Hank! Sometimes one has to improvise to get the job done.
matt392 (author)joekurm2016-05-03
It works quite well - I used it recently to unbox a few dozen computers at work.
cstrong278 (author)2016-05-01
Really
matt392 (author)cstrong2782016-05-01
Some of the best Instructables are the simplest ones. ☺
About This Instructable
310views
2favorites
License:
Bio: Occupation: Tech Support
More by matt392:2nd Method - Using Hole Saw Without ArborUsing Hole Saw Without ArborBox for Raspberry Pi Model B and Power Supply Made From Wood Shims
Add instructable to:
