3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Hand Truck From a Shopping Cart in Minutes
I need to move some stuff. I can't find my hand truck (moving dolly). Damn. I must have loaned it out.
Am I going to go buy another one? No. I'm going to make one from a shopping cart and frankly Scarlett, Tara the land, as God is my witness,  I'll never run out of hand trucks ever again!
It turned out great. Not only is it a good hand truck, it also works great as a four-wheeler floor dolly.
Time: It took an hour and fifteen minutes to build this while taking pictures, figuring out how to do it, and not rushing. The next one would take less than an hour.
    Tools Used:
safety glasses
dust mask
angle grinder with thin cutoff wheel
    with grinding wheel
I used my solar welder with spool gun and flux core welding wire. I wore my good respirator mask under the welding helmet. I don't want to get manganese poisoning.
You don't have a welder yet?  Make your own stick welder or weld from car batteries.
Step 1Donor Cart
Donor Cart
I got this bent shopping cart off the train tracks in Emeryville. A train removed the basket, which was a big improvement. I've been using it as a lowboy dolly ever since. Turned on its side it almost looks like a hand truck already!
42 comments
1-40 of 42next »
Nov 13, 2011. 7:57 AMDenver395 says:
Right is right and stealing the property of a retailer, damaged or not is no excuse
for doing what is wrong. When I see your item, I will know you your ethics suffer from some sort of rationalizational flaw. Seems you have alot of friends here.
Oct 2, 2011. 11:22 AMI am in the shed! says:
This has got to be the most useful "wheely" I've made... I welded the lower castors in the straight line position on mine, that way when used flat ie on all wheels it is much more controllable.
Jan 3, 2010. 12:59 PMsmooth97 says:
what  kind of cart did he use in the demonstration?
Mar 28, 2011. 10:04 AMHand Truck says:
Not a Magliner Cart! Those wouldn't break. Probraley some other no name brand.
Feb 9, 2011. 8:52 PMHand Truck says:
The guy who could show everyone how to make a convertible hand truck out this shopping cart will get a medal!
Feb 8, 2011. 9:56 PMHand Truck says:
He probably uses the cart that I always ended up with in the grocery, You know what I'm talkin about, when you end up fighting with the cart your whole shopping trip. So bless him for getting rid of it!
Dec 22, 2010. 2:06 PMhintss says:
the kind thats hit by a train, I think
Feb 22, 2010. 9:53 AMMorganbarker says:
 I've re-purposed several shopping carts, and plan on making an instructable or two out of the process.  I've never felt bad about tapping from the vast resource of abandoned carts,buggies,trolleys or whatever you call them locally.  The average unit cost to the retailers is 75-100 dollars.  I believe the most expensive models are somewhere around $400.  Shopping cart theft/loss costs retailers about 800million/year world wide.  Would you believe that if you bring a lost cart back to it's home, the owner won't reward you for your good deed?  I've tried.  So, screw 'em, I'm getting free welding carts, hand dollies, furniture, tool carts, automechanic's creepers and whatever else I can think of making out of them.  And when the pang of compassion for the poor retailer's loss hits me, I generally do the right thing and at least return the portions of cart that I don't use back to their lot.
Mar 20, 2010. 9:50 PMkaro818 says:
i was actually looking for go cart frame nd this came up nd this was a realy great idea ima realy have to try this it will work!!!! for a go cart frame
Feb 22, 2010. 9:55 AMMorganbarker says:
 Oh, I should clarify that I've never stolen a cart from a retailer.  I happen to live in a part of town where they tend to show up right in front of my driveway from time to time.
Nov 25, 2009. 8:13 AMsmooth97 says:
would you be able to buy the cart from the store?
Jan 1, 2010. 7:28 AMsiafulinux says:
That's what I was thinking, perhaps even the manufacturer. As an example, premiercarts.com.
Nov 12, 2009. 9:33 AMdddddd says:
1: knowing
    You know someone else stole that shopping cart.
2: taking of the property of another
    You know that it doesn't belong to you.
3: with the intent of permanently depriving them of it.
    You know you're never giving it back, no matter how much you "honestly" intend to.
Let's apply some Kantian principles: if it is ethical for you to do this, then it is
ethical for everyone to do this. Imagine that world. Is that too much philosophy for you?
And your justification that the store "owes" you this shopping cart: do you think that profit is theft?
You are not excused for your petty crime just because Georgey and Dickey
were enormous criminals that happened to lead this country, of for the behavior
of this country via its foreign policy.
The fact that you have made an entirely separate step to defend the theft of a shopping cart indicates that you are in a gray enough area, ethically, that you feel exposed to criticism.
I will grant you that the cart was damaged beyond repair before you took it from a railroad right-of-way, and that no store was going to want it back after that. You could have left it at that, and allowed other people the option of their own ethical choices. I don't know why you went on to condone theft.
You call your detractors "young philosophers". What have you got against young people? Do you think that you are excused for your petty crime just because you are old? What is it?
Nov 12, 2009. 12:45 PMtristantech says:
Stealing a shopping cart from the store is not right, but if you found it beat up and broken by a railroad track, I think your are OK. No store would want it back.
Nov 12, 2009. 12:49 PMtristantech says:
On more though: If you really find a shopping cart by the railroad or in the woods and it really is "abandoned property" (the store doesn't want it back), wouldn't you be doing the world a favor by picking up litter and making good use of of it instead of letting it rot and pollute the land?
Nov 21, 2009. 6:13 PMstncilr says:
no, actually you can be charged for trespassing.
Which is a crime.
Burn in hell...
(i kid. i kid.) Props for the theft. Capitalism sucks.
Nov 12, 2009. 12:31 PMdzent1 says:
Tim, you are living proof that a correctly functioning mind is still a possibility in America. Thank you for the many years of creative inspiration you have graciously provided (at no charge!) for the many of us in this country who are not afraid to think outside the box, physical, mental, spiritual or political, that mass media and inferior, politically-gamed education has trapped contemporary American society in.
Your philosophy on playing fair is plainly evident, and I find it offensive that some of these guys attempt to slam you without admitting that you very plainly told the reader not to steal a cart, but to ask for a damaged one from a place of business.
And I couldn't agree with you more on the disgusting behavior of the government during the disastrous (in EVERY way possible) tenure of the Bush/Cheney administration. Thank God for our children's sake and the future of the planet that they are gone.
And thank God you're still here as a testament to real American ingenuity. A long life and much happiness to you.
Nov 13, 2009. 6:33 AMAmyLuthien says:
Nifty!  My father made one very similar to this years and years ago - and before anyone thinks they need to rag on my deceased father for the crime of shopping cart theft, it was an old, rusty shopping cart from a building he was demoing, the store was no longer even in business, and rather than throwing it in a landfill, he brought it home and re-purposed it.  :)
Dear old Dad did one thing a bit different with the dolly he built, that I find extremely handy, so I figured I'd share it with you.  He made the handle adjustable so you can use it in the upright position as seen here, or remove the handle and replace it at a 90 degree angle and use it as a cart (while it is resting on all four wheels.)  This way, you can stand upright to pull it along.  It's very useful for hauling multiple bags of gravel, dog food, etc.
Nov 12, 2009. 7:40 AMAZ Girl says:
I sure hope that to get that nice shinney, not bent up shopping cart.....you did not go get it for the local store.  Too many people are hijacking them as it is and it just makes the cost of what we buy go higher in price!!!!  We do not need to be stealing shopping carts!!!!!!
Nov 11, 2009. 6:04 PMSandDevilJack says:
Politics begins when two people interact.  There is no escaping it on this little, interconnected world of ours.  Tim is spot on in his assessment of the modern world and the people (if we can call them all that) who have made it what it is.  We are lucky, in the Western "1st World" at least, to have the right to speak our minds and work for changes that can hopefully correct the abuses, neglect, and ignorance of the past.  It would be irresponsible not to.  And kudos on a great project!
Nov 7, 2009. 7:59 PMclark says:
 Is it really necessary to bring politics into this?
Nov 8, 2009. 1:29 PMmadhops0620 says:
It's always necessary to bring politics into otherwise non political discussions.
Nov 8, 2009. 10:10 PMclark says:
 i really hope your being sarcastic...
Nov 8, 2009. 9:04 AMJerryMopar says:
yeah, its just a good idea to reuse something that might get thrown away otherwise, there was really no need for politics IMHO
Nov 8, 2009. 10:24 AMclark says:
 I understand where your coming from. and I loved the project, i thought it was very well put together and very creative. And i think its great that you repurposed something instead of it ending up in a landfill.  Its just that i feel this isn't the place to share political ideas.
Nov 12, 2009. 12:46 PMdzent1 says:
Tim is one of the guys who made this site what it is. I think he should say WHATEVER is on his mind. Those who don't like it can always vote with their mouse and look elsewhere. A lot of us appreciate the fact that he speaks his mind and would never change that beautiful aspect of a superior person.
Nov 8, 2009. 6:37 PMSinAmos says:
I love it.  Shopping cart thefts go up.
Nov 8, 2009. 12:49 PMeulaliaaaa! says:
Oh,  you mean a dollie.  At first I saw the title and I was thinking "Cool!"  But then I clicked on the link and I saw that it was just a dollie.  Pretty cool anyways.
Nov 4, 2009. 6:17 PMZaphod Beeblebrox says:
yet another very useful,and funny ible by the king of awsomeness
Nov 5, 2009. 3:08 PMIts Giggles says:
Agreed.
This indeed is true; I say the same as ripstikfan. :)
-m
Nov 5, 2009. 3:42 PMZaphod Beeblebrox says:
why do you say m at the end when ur username starts w? an L?
Nov 5, 2009. 8:05 PMIts Giggles says:
Lol "la souris" means the word "the mouse" in french.
But ive been trying to change my username for a month now. :P
My name is monica, thats the reason for the 'm'.
Nov 6, 2009. 5:09 PMZaphod Beeblebrox says:
ooohh........
Nov 6, 2009. 10:26 AMbongodrummer says:
Nice! I like it a lot!
Nov 6, 2009. 9:59 AMmasterochicken says:
Does it rattle like a shopping cart?
Nov 6, 2009. 7:23 AMwoodyardboy says:
Very handy info mate. In another life, we'd have been brothers.
Nov 5, 2009. 6:42 PMBartboy says:
I question the legality.
Are you allowed to use a shopping cart you find on the side of the road if it is several miles from a grocery store?
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
