3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hand crank USB charger / LED headlamp
Charge your mp3 player and light your way anywhere anytime!
This DIY gadget makes a highly satisfying project and is extremely useful for long road trips, mp3 players with tired batteries, plain neatness, and impressing your friends.
The idea is very simple: use a crank charge headlamp and re-route some of the power from the light to a USB port for charging USB devices. We rely on the battery to soak up the voltage peaks so that while you're cranking, it should be around 5v.
P.S. if you like this, please vote so in the back to school contest.
Step 1Materials
Materials
Materials and tools you will need:
-Hand crank headlamp: http://www.leevalley.com/en/garden/page.aspx?cat=2,40731,58277&p=58277
-Female USB port single or double  (you can get them out of old computers)
-Knife
-Wire
-Soldering iron & solder
-Multi tester
-Small screwdriver
----------Disclaimer  disclaimer------------
This project is "do at your own risk". In other words, I'm not responsible if you fry or damage something in the process. Yada yada yada now let's get on with it.
8 comments
Feb 3, 2011. 2:54 PMsalz777 says:
Hi fellas,
I wonder, is there any way to store it up and charge whenever the switch is on? (assume we attach switch to control the power flow)
Dec 7, 2010. 4:11 PMjehovahgodofgaps says:
I am working on this instructable and I wired it right from + on the circuit board to the positive on the usb port and the negative from board to the - if the usb and i am only getting 3.9 volts and it wont show my phone as charging but it does say mp3 charger. is this power enogh to charge a phone or do i need a beeffer crank and also the batter is warm to the touch but its not shorted its over 2.6 m ohms between the terminals and it reads as 3.9 volts.
thanks for the instructable
Dec 8, 2010. 4:49 PMjehovahgodofgaps says:
earthling
I just got it to work i charged the cranks chargers internal battery over the dc in port via usb and it now reads 4.13 volts and when i hook it up to my phone it shows the lighting bolt on the battery meter that says its charging. since i commented i also had a bad contact in the first usb port i soldered in. while desoldering the first usb port i must have pulled it to hard and the contacts pulled out the back but i replaced it with a better usb outlet
Sep 11, 2010. 6:46 AMLuciferRex says:
Quick question: How efficient is this at charging your mp3 player?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:Earthling!
