The idea was originally for construction in wood. It came from a village technology handbook. I built mine out of iron and cement, and came up with the funnel plunger idea. The rectangular tank uses a special sheet metal with holes for plastering called Hi-rib. It is sealed with a cement-base sealer.
My method is to soak the clothes in detergent and water overnight, pump them for about 5 minutes in the morning, rinse them twice and hang them up on the clothesline.
It's good exercise, and it consumes no electricity.
Remove these ads by
Signing UpStep 1Inside the Washer
The funnels can be easily replaced if they eventually break, but they hold up quite well. The bright red funnel was recently replaced.
I visualize maybe salvaging a front loader and rigging a bike sprocket to drive the drum. Super clean clothes and low ecological impact.
I would like to see you build a bicycle powered centrifuge to extract more water so the clothes will dry faster plus you could get some good aroebics. I got the idea for the centrifuge in Australia. The local laundromat was equipped with washers, centrifuges and dryers. The clothes could be run through the centrifuge extracting almost all of the water and then a brief stay in the dryer and they were ready to hang/fold and put away.
I love your simple and inexpensive building techniques. However,I think most cities in the 'States' are now coding out such things as hanging laundry out to dry. The poles and lines are too 'ugly' and damage 'property values'.
This says nothing of your structures that would send code enforcement officers on a citation writing binge.
A wringer wouldn't be a bad idea to try, but hand wringing and a good drying day still work.
kenkou chou jumyou Thinkenstein
(Thinkenstein wishes you good health and long life, also.)
BTW what is the name of the book? I left mine with a carpenter in Cambodia and have been trying to find another for more than 10 years
Village Technology Handbook. The above link takes you to an online copy.
http://www.fastonline.org/CD3WD_40/JF/410/02-64.pdf
No wringer. I hand twist the clothes to get most of the water out and then just hang them up to dry. It ain't perfect, but it works.
Thanks for replying, sorry I'm so slow in getting back. My connection which is somehow still legal for my phone company to provide is maxed out at 10-15kbps and wont seem to do the pdf. In the past, once I joined on better connections I had no problem getting them. The link may be good but it's not getting through :( Help! Out here in the 'affordable' land sticks, the internet superhighway is a super toll road that I can't afford, netzero's $10/month is my max. The link may be good, but net segregation isn't.
Thanks for this instructable btw, seeing someone who's actually used the vita washing machine design gives it more credibility to me, even though I'd still like to see a wringer integrated I can certainly understand making do. :) Cool adaptation with the ferro-cement.
~Tinker52
Enjoy. Lots of interesting projects in it.
http://www.cd3wd.com/cd3wd_40/vita/vthbook/en/vthbook.htm
Enjoy, its got loads of awesome useful stuff!
http://www.wisementrading.com/washing.htm
