3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hand-powered WASHING MACHINE
I have probably been washing clothes in this hand-powered washing machine for over 25 years. It has two funnels inside the tank that serve as plungers, agitating the water every time the handle is pumped. The inside dimensions of the tank are: 15" tall, 33" long, 14" wide.
The idea was originally for construction in wood. It came from a village technology handbook. I built mine out of iron and cement, and came up with the funnel plunger idea. The rectangular tank uses a special sheet metal with holes for plastering called Hi-rib. It is sealed with a cement-base sealer.
My method is to soak the clothes in detergent and water overnight, pump them for about 5 minutes in the morning, rinse them twice and hang them up on the clothesline.
It's good exercise, and it consumes no electricity.
Step 1Inside the Washer
Inside the Washer
The funnels go up and down. Shape-wise, the funnel is streamlined and cuts the water as it moves upward. Coming down, it creates more churning action because of the less streamlined bottom.
The funnels can be easily replaced if they eventually break, but they hold up quite well. The bright red funnel was recently replaced.
59 comments
1-40 of 59next »
Apr 16, 2012. 10:53 AMoldmantime says:
This is pretty simple/ingenious. Laundry is one of those tasks that must happen but we are very tied to power consumption to achieve that end.
I visualize maybe salvaging a front loader and rigging a bike sprocket to drive the drum. Super clean clothes and low ecological impact.
I would like to see you build a bicycle powered centrifuge to extract more water so the clothes will dry faster plus you could get some good aroebics. I got the idea for the centrifuge in Australia. The local laundromat was equipped with washers, centrifuges and dryers. The clothes could be run through the centrifuge extracting almost all of the water and then a brief stay in the dryer and they were ready to hang/fold and put away.
I love your simple and inexpensive building techniques. However,I think most cities in the 'States' are now coding out such things as hanging laundry out to dry. The poles and lines are too 'ugly' and damage 'property values'.
This says nothing of your structures that would send code enforcement officers on a citation writing binge.
Oct 7, 2011. 3:10 PMjavajunkie1976 says:
Great idea. I volunteer at a non-profit rabbit shelter and we usually spend about $60.00 a week doing laundry. If this is as easy as it looks to put together, I may have to scrounge the materials to make it. Our laundry is mostly bedsheets and towels. The only modification I can think of right now would be to hook it up to a stationary bicycle and build a rotating drum dryer as we have no ability to hook up a clothes line.
Aug 10, 2010. 6:44 PMgnomedriver says:
Great setup and a good way of staying off the power grid. I was without a washing machine for six months or so and would wash things in the bathtub. It got a little tiresome and your rig looks much better. Quicker and easer. Have you tried rubber sink plungers instead of the funnels?
Nov 25, 2010. 9:31 PMDELETED_kage_no_akiri says:
(removed by author or community request)
Mar 8, 2011. 12:20 AMbgentry says:
What about those funnel shaped laundry plungers (very reasonably priced at Lehman's) they work pretty well by themselves in a six gallon bucket with a lid (for long term camping)
BTW what is the name of the book? I left mine with a carpenter in Cambodia and have been trying to find another for more than 10 years
Mar 19, 2011. 11:11 PMthn says:
Download complete book Village Technology Handbook from CD3WD (14Mb pdf):
http://www.fastonline.org/CD3WD_40/JF/410/02-64.pdf
Nov 26, 2010. 9:00 AMDELETED_kage_no_akiri says:
Mar 2, 2011. 5:58 PMTimmyMiller says:
where did you get the tub/tank thingy?
Oct 19, 2010. 3:28 PMtinker52 says:
The pdf for this seems to be broken, unless it's my slow connection. Could someone check it? Also where's the wringer to get the cloths ready to hang on the line?
Nov 26, 2010. 8:52 PMtinker52 says:
Thinkenstein,
Thanks for replying, sorry I'm so slow in getting back. My connection which is somehow still legal for my phone company to provide is maxed out at 10-15kbps and wont seem to do the pdf. In the past, once I joined on better connections I had no problem getting them. The link may be good but it's not getting through :( Help! Out here in the 'affordable' land sticks, the internet superhighway is a super toll road that I can't afford, netzero's $10/month is my max. The link may be good, but net segregation isn't.
Thanks for this instructable btw, seeing someone who's actually used the vita washing machine design gives it more credibility to me, even though I'd still like to see a wringer integrated I can certainly understand making do. :) Cool adaptation with the ferro-cement.
~Tinker52
Feb 19, 2010. 3:14 PMscmtngirl says:
I really like this. But I just can't get over how algae-covered everything is. When I think of laundry, I think stark, clean, white, I guess. This would be a good alternative to the expensive James washer. Great job!
Dec 26, 2009. 9:18 PMtimmybam says:
Great simple design. Will try and use one funnel and a 20 litre bucket for washing small loads.
Sep 5, 2009. 3:02 PMEnrique III says:
Smart idea, and it also looks very reliable, and very cheap to build. Thanks...
Aug 10, 2009. 3:42 PMrookie1 says:
I'm thinking about making papercrete for the outside of a sandbag shed. This looks like just what I need to pulverize the paper in water.
Aug 5, 2009. 4:51 AMDixiebitch says:
I love the idea--I live on mountain and this would be great. I just don't see the diimensions for the actual washing chamber--could you post them? Also, you said the original design came from a book on village technology--could you give me the name? Thanks DB
Jul 31, 2009. 2:13 PMbob_the_builder21804 says:
An absolutely awesome instructable. I use a 1940's wringer washer but would love to make something like this. Thanks for posting it Thinkenstein.
Jul 27, 2009. 2:19 PMGloomy_Goth says:
I found a copy of this book "Village Technology Handbook"
http://www.cd3wd.com/cd3wd_40/vita/vthbook/en/vthbook.htm
Enjoy, its got loads of awesome useful stuff!
Jul 28, 2009. 2:56 AMGloomy_Goth says:
Your welcome! Anytime! It looks like it is packed with valuable information.
Jul 23, 2009. 9:55 AMiectyx3c says:
This is great. Nice, clearly written Instructable with great photos and illustrations. Do you recall the name of the village technology handbook?
Jul 22, 2009. 9:10 AMEv says:
If you put a lip around the cover inside the tank, spills would be reduced.
Jul 17, 2009. 10:09 PMbruc33ef says:
Easier: Get a Yukon Plunger!
http://www.wisementrading.com/washing.htm
Jul 18, 2009. 8:47 AMTool Using Animal says:
But yours does offer mechanical advantage over the plunger.
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
341
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
