Step 9Finish Up
But since your first and last pages actually contain content (including the important TOC on the first page), you'll want to use paper specific to this task. I decided to use MAKE's original wraparound cover as my endsheet for the front cover board. Its thick stock works well for extra support and looks quite nice. I simply trimmed it to fit (leaving a the same distance to the each edge of the book and pasted the back of the wraparound cover to the front cover board. Allow glue to run into the spine of the wraparound cover, because you'll want to use that area to cover the point where the cover meets the spine and extend into the front page by about 1/4". This grips the endsheet to the book block to add reinforcement to the spine.
You'll need to cover the back cover board in the same way. Since I'd already stripped the cover from MAKE: Volume 2 (my next bookbinding project), I went ahead and used that for my back cover (guess I'll need to be more creative with picking my endsheets when I bind Volume 2), trimming off the unwanted back cover ad, but leaving enough room to allow the 1/4" spine area to cover the gutter and connect the endsheet to the final page.
Put fresh pieces of wax paper between the covers and the book block, and set under heavy weights to dry overnight. You'll wake up to a copy of MAKE that will last forever, as well as look unique and serve you well.
As you can see, as promised, the finished book lies flat, perfect for following an article's instructions while working on a project like this one.
Now, on to Volume 2 ...
5
comments
Add Comment
BrianSawyer (author)
says:
says:
says:
Add Comment
